beveled vs flat washer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbillcee, Apr 23, 2007.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    is there as easy way tell if the washer that needs to replaced was a beveled or flat?
    the washer is missing
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    All faucets are designed to use flat washers. Bevel washers are used mainly for faucet seats that are damaged or wore beyond stem travel, therefore the thicker washer makes up the difference.
    The bevel attempts to seal the water flow from the interior opening of the seat, rather than the flat raised edges of the seat.
  4. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    thanx for the info
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Are you saying that some seats just cannot be removed by any means and that using a beveled washer could save you from having to replace the entire shower manifold?
  6. Dunbar Plumbing
    Apr 18, 2005
    Yes. But if that seat has a rough edge or chip in the surface....those bevel washers will deteriorate the same as a flat washer.
    I keep bevel washers on the truck but only use them in extreme measures or I cannot remove the seat, or grinded the seat as a last resort.
Similar Threads: beveled flat
Plumbing Forum, Professional & DIY Advice When you have a beveled metal washer intergrated into a faucet supply hose..... Aug 9, 2012
Plumbing Forum, Professional & DIY Advice Black spots on dishes and flatware in dishwasher Dec 18, 2016
Plumbing Forum, Professional & DIY Advice Like a cow on a flat rock Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Flat vs pointed-top tapered threads Sep 4, 2016
Plumbing Forum, Professional & DIY Advice Flat vent Feb 9, 2016
