Better valve, ball or globe?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tao_of_howe, Feb 2, 2005.
  1. tao_of_howe
    tao_of_howe New Member
    Nov 22, 2004
    Is one type better than the other? Ball valves or Globe valves? I have had trouble with stuborn globe valves in the past, and less trouble with ball valves. Is it just that the globe valves are more common, more chances of finding a bad one, or are they less reliable? I have replaced every globe valve with a ball valve that I have had to work around. Am I right in doing this? Or, did a couple of bad globe valves give me irrational bias?
  2. hj
    valve
    You must live in a "weird" area if you have that many globe valves around. I see a globe valve about once every five years. But that being said, typically the two valves are designed for different functions. A ball valve, or gate valve, is design to give the maximum flow with the least restriction and should be fully open or fully closed. A globe valve is for use when flow modulation is required, but maximum flow is not a factor. It can be operated at any degree of modulation from fully open to fully closed. The quality of the valve usually determines its functionality, as it does with any other valve. Here there are mostly imported gate valves used and many of them have broken after a few years of service.
Similar Threads: Better valve
Plumbing Forum, Professional & DIY Advice Dual Outlet shut-off valve for better flow? Jul 6, 2013
Plumbing Forum, Professional & DIY Advice Are some checkvalves better than others - Water Backflow Preventer Sep 22, 2011
Plumbing Forum, Professional & DIY Advice Which one is a better Sump Pump Mar 5, 2016
Plumbing Forum, Professional & DIY Advice Is a slip on tub spout better than a threaded one? Apr 6, 2015
Plumbing Forum, Professional & DIY Advice Which condensate drain is better? Oct 30, 2014
