Better alternatives to Moen posi temp
Discussion in 'Toilet Forum discussions' started by jbrickm, Feb 11, 2012.
  1. jbrickm
    jbrickm New Member
    Feb 11, 2012
    Atlanta, GA
    I'm looking at replacing the Moen posi temp cartridge in the guest bathroom for the third time in 3 years. I understand that the posi temp by design gets stuck if not used regularly.
    What alternatives are there for the posi temp that will keep working even if used infrequently? Thanks
    P.S: I'm a noob and not a pro
  2. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Use a Delta.But really you need to exercise the valve on a regular basis. The trap for the drain would go dry anyway if you didn't.
  4. jbrickm
    jbrickm New Member
    Feb 11, 2012
    Atlanta, GA
    Thank you! To replace the Moen with a Delta tub and shower faucet kit, is it an advanced i.e. pros only job or is it do-able by a DIY guy? I'm pretty handy but the only plumbing "project" I've done is to replace a flush valve in a toilet.
  5. jadnashua
    You'll likely need to cut pipe and solder things back together to install a new valve. If you can't open the wall behind the thing, then you'll have to do it from the front. From the front, the hole isn't big enough, so you have to make it bigger. They do make rennovation or remodel plates designed to cover that larger hole (only needed if you need to go from the tub/shower side). Or, if it is tiled, you may be able to rebuild it and put in new tile. So, depends. Certainly easier to remember say once a month to open the valve and let it run for 30-seconds or so...
  6. Rob418
    Rob418 New Member
    Apr 23, 2014
    Chimney Reliner
    CT
    Jim,
    Am I better off, in your opinion, to return my Moen and install a Delta?
  7. hj
    I would, but only if you use the Delta 1700 series trim with the separate temperature and volume levers.
Similar Threads: Better alternatives
Toilet Forum discussions Better Toilet for Hard Water/Iron Conditions? Jan 30, 2017
Toilet Forum discussions Is the Toto Drake II better than the Toto Drake? Sep 27, 2013
Toilet Forum discussions Which models work better? Ultramax & Drake with 1.6 gpf or Ultramax II & Drake II ? Jul 27, 2012
Toilet Forum discussions AS Cadet PRO - better or worse? Jul 23, 2012
Toilet Forum discussions Better solution for tank bolt leaks for Toto toilet? Nov 16, 2010
