Betta Flo and 1 1/4" poly???
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by MATTHEW1, Jan 24, 2010.
  1. MATTHEW1
    MATTHEW1 New Member
    Jan 18, 2010
    Oregon
    Hi my name is Matthew...I'm installing a new 1.5 H. 15gpm at 110' and was going to use 1 1/4" poly to keep pressure loss down. Does this cause any problems besides the extra cost? My well is also sleeved with 4 " pvc pipe and do I do anything different to install?
    I"m very excited to install a CSV1Z and smaller pressure tank. What size would you folks think would be a minimum size?
    Thank you for your help...Matthew
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Nothing wrong with 1.25" poly, and with the CSV, you can use as small as a 4.4 gallon size tank.
  4. MATTHEW1
    MATTHEW1 New Member
    Jan 18, 2010
    Oregon
    So the CSV1Z will let 2 gpm back to the tank correct? So a bigger tank will let the pump run longer?
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    The 1Z will fill the tank at 1 GPM. With a larger tank you would just set the valve at 58 PSI with a 40/60 pressure switch, so it doesn't take to long to fill the tank.
Similar Threads: Betta poly
Pumps and Tanks Well Forum & Blog. Water is life. Using correct Poly pipe ? Yesterday at 8:47 AM
Pumps and Tanks Well Forum & Blog. Water is life. Poly vs schedule 80 pump vibrating loose Feb 14, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Can I replace galvanized drop pipe in 2" well with black poly? Dec 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Is it ok to run CPVC from polypropylene to well tank in house Nov 9, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Black Poly Pipe: How long does it last? Jan 21, 2015
