Best way to pump naturally flowing artesian
Discussion in 'Pumps and Tanks Well Forum & Blog' started by mark_g, Jun 29, 2009.
  1. mark_g
    mark_g New Member
    Mar 3, 2009
    We completed drilling our well last December. It's 385', fully cased: 120' @10", 195' @7", 40' @5" into bedrock.
    Since then, well has been producing 27gpm of clear water at the wellhead that we've piped off to the brook until we complete construction on the house. Flow has been constant, although water slows (gurgles) as if to catch its breath, then resumes flowing.
    We are planning to use two pitless adaptors: one to carry potable water, the other to direct the natural overflow. Our well driller wants to use a submersible pump set not too deep for the potable needs, then another pitless adaptor below frostline to catch the natural flow.
    The potable water needs to be chlorinated to kill moderate bacteria levels. To maintain hi flow rates, it's been suggested that 240 gal retention tank(s) be used to maximize contact time of the water with the chlorine, then dechlorinate w/carbon filter. It will serve weekend needs up to 4½ bathrooms in two houses. Some days very busy, some days idle.
    Which scenario is best -- or can you propose something else?
    (A) Use a jet pump to bring water to the holding tanks, chlorinate & aerate in the tanks, dechlorinate w/post filter, then use a small pressure pump to pressurize flow to the house. I have read that supplemental booster pumps offer better "city-like" pressure than a bladder tank. I don't understand if a jet pump would be better than a submersible in this application.
    (B) Same as (A) but use a submersible pump set shallow --100'? -- but still no bladder tank.
    (C) Same as (B) with submersible pump, but use a bladder tank ahead of the holding tank (to me, both bladder tank & holding tank sound redundant).
    (D) Use a submersible pump, chlorinate via liquid injection ahead of the bladder tank, oversize the bladder tank to eliminate the holding tank, then carbon filter before going to the house.
    The natural flowing "extra" water will come off the below-frostline pitless and also be piped to the house, through a ground source heat pump, then dumped to the brook. That water will not be treated--we've run enough lab tests to know that we should be okay in this open loop setup, and pump & dump is allowed if the water is not chemically treated.
    Thanks for helping me sort this out. --Mark
  2. Cookie
    Cookie .
    Oct 7, 2005
    Mark, I wish you luck with your well.
  4. mark_g
    mark_g New Member
    Mar 3, 2009
    Michigan has one of the most stringent regulations of any state--I've spoken to a cpl of drillers in your state. But the consistent loophole is that if capping the flow will cause other issues, you can at least petition to keep the well flowing. Our does not have a lot of pressure, but imagine capping 27gpm of water--it will find it's way up somewhere.
    Are flowing wells common in Michigan? Here in NY State no so much.
    --Mark
Similar Threads: Best pump
Pumps and Tanks Well Forum & Blog How to best control well pump and cistern Sep 23, 2015
Pumps and Tanks Well Forum & Blog The best deep well submersible pump and motor? May 31, 2015
Pumps and Tanks Well Forum & Blog Best pump for hard water also, please review our setup & suggest other possible improvements Oct 22, 2014
Pumps and Tanks Well Forum & Blog Best Pump? Torque Arrestors or Not? PVC vs Galvanized? I Need Some EXPERT Advice! May 15, 2014
Pumps and Tanks Well Forum & Blog Lake water pump cracked housing - trying to determine best option with changed needs Apr 29, 2014
