alreadyinuse
We have a new Rheem electric water heater with 2 elements.
We have temperature set to 130F
If we don't use hot water for hours, we notice that the lower temperature reading can be 113 F for hours until hot water is used. The upper temperature reading in the tank generally remains near 130F.
Appears that the heater design turns on the upper element only during periods of non use. I am disappointed with this design. I'd prefer that the entire tank be maintained close to the set temperature during periods of non-use so we can control risk of Legionella.
During the summer on some days, we may take shower in morning and not use hot water again for nearly 24 hours later. Maybe longer on weekends.
What can we do to best handle Legionella risk? Convert to a 1 element electric water heater, if there is one for a residence?
Is there a brand of water heater that would maintain the set temperature of all the water in the heater during 20 hours of non-use?
I suppose we can turn our water heater up even higher to 140 and install a mixing valve. I am not so much a fan of this in the event the valve fails. 140F is too hot. We don't want to be going to hospital.
Not sure if we have space for converting to a tankless gas heater.
thank you in advance.
