best way to cut pvc pipe?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by scrappy, Oct 18, 2009.
  1. scrappy
    scrappy New Member
    Mar 10, 2007
    New York
    I have a pvc drain pipe that needs to have a broken joint cut of and replaced. what's the easiest way to do this? the pipe rests up agains a joist but I can get a little space off the joist. I'm thinking sawzall? what's the best type of blade for the pvc?
    thanks for the help.
    Scott
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You can use hacksaw if there is enough space. I like a good blade that is really taut and I mark the pipe all the way around so I can be sure the cut is square. There are also small saws that require less space. Once the cut is made, I use knife to ream the inside and outside edges of the cut. You should keep the cut as square as possible, but it is not necessary to be absolutely perfect.
  4. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    with a sawzall, I think a metal blade works the best. I like the white Ridgid blades.
  5. hj
    Pvc
    For tight cuts on PVC, use a piece of nylon string with loops on each end for handles and "saw" through it, or buy a "wire saw" for cutting PVC.
  6. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I've used the string method for sprinkler repair.
  7. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I saw it on TOH once. :) Awfully squeaky, but it worked. Neat.
  8. psjr56
    psjr56 Member
    Apr 23, 2009
    S. Jersey
    Sawzall with metal cutting blade will cut it like a hot knife through butter but it will vibrate so get someone to hold it if possible.
  9. riftsawn
    riftsawn New Member
    Oct 20, 2009
    Colorado
    I am a woodworker, so naturally I use what tools I already have around. Anyway I use a japanese cross cut saw in those situations. They are very thin, flexable, and cut on the pull stroke. They cut through PVC like you wouldn't believe and I have never had one chipout the pvc like a sawzall. You can get a cheapo at any big box store.
Similar Threads: best pipe
Plumbing Forum, Professional & DIY Advice Best Methods for Revealing Pipe Issues Inside Walls? Dec 15, 2016
Plumbing Forum, Professional & DIY Advice (Another) Single to double vanity - best way to reroute pipes? Apr 10, 2016
Plumbing Forum, Professional & DIY Advice Best way to connect ABS drain kit to brass pipe Jan 19, 2016
Plumbing Forum, Professional & DIY Advice What kind of drain pipe is this? How can I best transition to PVC? Feb 8, 2015
Plumbing Forum, Professional & DIY Advice Best method to determine fall with trenched pipe Jun 17, 2014
