Andrew_in_Ottawa
I just replaced a 65 year old bathtub and the drain and overflow locations for the new tub are significantly different from the previous tub. This looks like it will require a replacement of the drain and overflow pipes. All of my waste piping is brass soldered at all connections. I have never soldered, so I would like to switch to pvc, or abs for the drain and overflow kit, but don't know how to connect those materials to the brass p-trap and piping below. Is it possible to cut the brass pipe above the p-trap and then connect using a rubber sleeve to the pvc, or abs drain kit just above it? I have easy access to all areas as the whole bathroom is torn to the studs and the basement has full access to the p-trap and waste piping all the way to the main stack.
Thanks for the help!
Andrew
Andrew
