Best way to clean out grease?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by PM5K, May 3, 2011.
  1. PM5K
    PM5K Member
    Oct 9, 2006
    San Antonio, TX
    First of all I didn't pour grease directly down the drain, I assume over time cleaning plates that had small amounts of grease on them built up over time.
    I wouldn't say the drain was clogged, rather I think the p-trap wasn't tight enough and it came off, causing water to come out. While I was checking it out I noticed all of the grease and did what I could to clean it out of the p-trap and the other accessible pipe.
    What's the best way to clean out any grease I assume is further down the pipe that I can't easily access? The sink still drains perfectly fine so I doubt it's much, it probably mostly got caught in the p-trap.
    TIA
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    If the inside surface of the pipe has a coating of grease in the pipe and the water is still flowing, I wouldn’t worry about it.........If you are determined to get it out you can try sodium hydroxide in some form. There are many drain cleaning products available. Grease and soap are similar except soap is soluble in water. Soap is made from mixing grease and sodium hydroxide also known as lye or caustic soda. There is a product called Red Devil Lye. It is mixed with water and if heated is very effective. I have used it to clean floors, remove paint and to clean drains. It will eat aluminum and produce hydrogen which can be explosive. Sodium Hydroxide can be a dangerous chemical and can cause burns to your skin and if it gets in your eyes it can cause blindness, so you need proper safety equipment. Most degreasers contain sodium hydroxide as their main ingredient.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Skip the chemistry lesson and get some Bio-Clean...
  5. Terry
    Aug 17, 2004
    Don't use Draino, unless you want to shorten the life of your pipes.
    It's better to go with something that eats the grease.
    I like Bio-Clean for that.
    I even sprinkle a little in the litter box to get rid of smell.
    Some cities require restaurants to use something like Bio-Clean
  6. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    One of the neat things about biologic agents like Bio Clean is that it contains bacteria that get into the pipes, and like to eat things like grease, so they multiply and sort of climb up the sides of the pipe and eventually clear away most if not all of those deposits.
    A pure chemical (i.e. nonliving) drain cleaner like lye (Draino and others) will just sort of cut a channel in the greasy deposit in the lowest part of the pipe, but leave the rest of the deposit alone.
    Definitely would recommend getting Bio Clean. Terry sells it here.
  7. PlumbPowerHouse
    PlumbPowerHouse Plumber
    Dec 10, 2009
    South Carolina
    We stay far away from Draino. Our techs carry Bio Clean on their trucks and also sell it to our customers. We love the stuff over here and we never have a problem selling it.
Similar Threads: Best clean
Plumbing Forum, Professional & DIY Advice Best way to install cleanouts Apr 8, 2008
Plumbing Forum, Professional & DIY Advice The Best Homemade Bathroom cleaner.. Feb 10, 2006
Plumbing Forum, Professional & DIY Advice Best Way to Splice Water Off This Sink Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Best Methods for Revealing Pipe Issues Inside Walls? Dec 15, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
