Best way to add 2nd vanity
Discussion in 'Remodel Forum & Blog' started by mthurlow, Oct 27, 2008.
  1. mthurlow
    mthurlow New Member
    Oct 27, 2008
    D/FW, TX
    I'm redoing the bathroom and trying to add a 2nd vanity. I've searched through these forums for most of the answers, but still have two questions.
    1) Based on the picture attached, which is the preferable method to attach the 2nd vanity, top or bottom picture? two sanitary tees or a double tee with cleanout?
    2) I haven't found any rules relating to a maximum horizontal run before going vertical into a waste/vent pipe. It's a 1.5" pipe dropping into a 2." Is this 6' horizontal run ok?
    ps. I left the P traps and other details out for clarity, but they will be installed. If however, there are other concerns with the image, I'd appreciate being alerted to my ignorance.
    Thanks in advance for your help.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    What image?
  4. hj
    sinks
    Two problems.
    1. No image.
    2. Do not use a double tee/cross.
    3. 6' is too far for a 1 1/2" arm.
    Use a "back to back fixture fitting" which any knowledgable retailer will sell you AND, in most cases you should install a cleanout tee below that fitting.
    [​IMG]
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    A 2" pipe can go 6' horizontal. Slope it 1/4" per foot drop. Use a 2" p trap too.
    David
  6. mthurlow
    mthurlow New Member
    Oct 27, 2008
    D/FW, TX
    Attempt at posting image
    This should be the image:
  7. Redwood
    Dec 15, 2007
    Service Plumber
    6' is a problem...
    It's too far.
    Move the drain over and use a double fixture fitting.
  8. mthurlow
    mthurlow New Member
    Oct 27, 2008
    D/FW, TX
    What is an acceptable distance?
    I will use a double fixture fitting. I finally found out exactly what those are and will get it.
    If 6' horizontal run is too far, what would make it acceptable? I can make it be 2" instead of 1.5" pipe. I can add a 2nd vent line that would go vertical from the left vanity and join the main vent above the ceiling. Is there something else I should do? Is there a particular section of the IPC that would address this issue? I didn't find it at first, but I can look again.
    Thanks again, Micah
  9. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    The issue hear is the distance between the sink trap and the vent. A larger pipe can go a longer distance, and the code states this.
Similar Threads: Best vanity
Remodel Forum & Blog I touched up wood vanity & want to seal/clear coat. What's the best for a bathroom? Jan 8, 2014
Remodel Forum & Blog Best Patio Door Manufacturer Sep 6, 2015
Remodel Forum & Blog Did I find asbestos? Aug 4, 2015
Remodel Forum & Blog What Type of Roofing is the Best Suitable and Long Lasting? Jun 9, 2015
Remodel Forum & Blog Best approach to a new 1/2 Bath Addition May 3, 2015
