Best Transition
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dlarrivee, Oct 29, 2012.
  1. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    I'm replacing a sewage ejector pump and installing a "Zoeller Tri-check" at the same time.
    The tri-check is a union check valve and ball valve in one unit, and is made of PVC.
    The pump is cast iron, the main line I'm tying into is 3" ABS.
    PVC for DWV is very uncommon here, but I'm required to have the ball-valve etc. due to local code.
    The ejector is right below the 3" abs line, so I will be dumping into the top of the line w/ a wye and 1/8th bend.
    There are female threads on the pump, and 2 sockets, one on either end of the tri-check.
    Where would the best place to transition from PVC to ABS be? I'm not planning on using transition glue, I was thinking female PVC adapter to male ABS adapter right after the ball valve before the 1/8th bend and wye...
    Is this threaded connection trustworthy?
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Why not a shielded neoprene coupling? Much handier when (not if) the time comes to dissassemble/reassemble
    the works.
  4. dlarrivee
    Jun 28, 2009
    Canada
    I have a Proflex 3000-22, I wasn't sure if these were meant for discharge on pumps though?
  5. Terry
    Aug 17, 2004
    The best place to transition from PVC to ABS is with a shielded coupling. That's a plus 1
  6. dlarrivee
    Jun 28, 2009
    Canada
    Great thanks guys, I've got the coupling already but was second guessing and thought I would check in here.
Similar Threads: Best Transition
Plumbing Forum, Professional & DIY Advice What kind of drain pipe is this? How can I best transition to PVC? Feb 8, 2015
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Best Way to Splice Water Off This Sink Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Best Methods for Revealing Pipe Issues Inside Walls? Dec 15, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
