Alternety
Like an engineer
I have 5 toilets in the house. I bought 5 Totos but did not consider mounting conditions. I got some units that I wanted and a couple that the wife wanted. Hers turn out to need drilled holes. I have infloor heat embedded in 2 inches of concrete. The plan was to keep heating tubes away from the toilets. The plan failed. The first contractor provided no pictures or documentation so I really don't know where the tubes are. Trying to figure it out by seeing if I can measure a heat gradient seems risky. Second contractor (main floor) gave me photos, but put tubes where the non-waste pipe mounted holes have to go.
I have one installed but not fastened which will have to be replaced. I am going to need at least one more unit that can mount to the waste pipe. I will move an installed Drake to another room.
My question is what to replace the Drake with? I have issues with the bowel cleaning ability of the Drake so that is a key point. I believe I want elongated, ADA and Sanigloss.
