Best Sump Pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Bill MD, Jul 7, 2006.
  1. Bill MD
    Bill MD New Member
    Sep 27, 2004
    Retired
    Berlin, MD
    I need to replace a submersible sump pump. I know I need to check the GPM of the old pump and get one with similar capacity. But I'm wondering what brand, model, etc. would be best. Anyone have any suggestions?
    Thanks
  2. Bill MD
    Bill MD New Member
    Sep 27, 2004
    Retired
    Berlin, MD
    Other Brands
    Thanks for the reply Bob. I'll keep Gould in mind. Since I first asked about this I found that Lowes and Home Depot have Flotec, Wayne, and Water Ace. Anyone had experience with these?
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    they are all junk
    The ones from Lowes are junk and not to be trusted.
    I have a pic at the bottom of this web page showing
    a 4 month old Wayne sump pump that failed and flooded
    out someone, (it cost $65.00)
    the best one you can install is a Zoeller like in the same picture
    with the wayne pump.....its the ABSOULTE best way to go.
    Get one without a switch then add your own verticle switch on the
    pipe.... the actual Zoeller pump will run forever ...its literally that good....
    the only thing that usually fails on any good pump
    is the SWITCH........
    So might have to change the switch every 10 years...
    but that would be very easy to do
    average cost for this set up is about $135.00
    http://www.weilhammerplumbing.com/sumppumps/
  5. Bill MD
    Bill MD New Member
    Sep 27, 2004
    Retired
    Berlin, MD
    More Questions
    Thanks for the info Mark. I looked and the pictures you attached. They really show the importance of buying a good sump pump.
    Just a few questions. What is the reason for the switch on the pipe? Is it easier to replace and check that way or is it more likely to fail if it is submerged?
    Also, what kind of switch do I get? Is there one made for this pump or do I have to improvise my own?
  6. Master Plumber Mark
    Feb 6, 2005
    sump pump
    sorry it took me so long to reply
    te Zoeller pump itself is about the best motor and pump
    you can buy.. the only problem with that brand is their
    switches are always a problem when they are built into the motor...
    MANY pumps are built that way and when they fail you are screwed.
    buying the pump only and buying a separate
    VERTICALMASTER Switch that goes on the pipe
    is the best combination and is very easy to change inthe future..
    if you buy any pump whhere the pump and the switch are
    integrated into one wire to be plugged into the wall ,
    if the switch fails you , you cant get the pump
    to come on........and you flood out...
    With two wires comming off the pump, the motor plugs into
    the back side of the switch , then it all plugs into power....
    If this switch were ever to fail you
    you can always unplug the switch and then plug the
    pump directly into power and keep the pump working
    untill the calvary arrives....
  7. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    I have lived 6 places in the last 10 years that had sump pumps. The one thing I will say get a trash pump or a sewage pump. Thais way you don’t have to keep the filter clean on the pump and it will be able to handle clumps of stuff up to 1/2 “ or so.
  8. Bill MD
    Bill MD New Member
    Sep 27, 2004
    Retired
    Berlin, MD
    Thanks for the advice.
    I ended up getting a Zoeller M53 which has a float switch mounted on the motor. I looked for the N53 that comes with the type of switch that you recommended but it seems like nobody around here stocks it and I didn't want to wait for a special order. Also the verticle switch needs a minimun amount of tether to operate and I was concerned that I did not have enough room in my sump. The pump I replaced is a Zoeller with a bad float switch. It's a sad looking thing but it still works. I'm going to see if I can get a replacement switch and use this old pump for a backup.
  9. sumppumppimp
    sumppumppimp New Member
    Sep 23, 2005
    Hey Bill,
    We can get you the new switch part number, just call 1-800-928-7867 ext 6
    and tell the them you need a new switch for your old pump. Very easy to replace and that way you will have a good back up pump just in case!
    1 person likes this.
  10. Bill MD
    Bill MD New Member
    Sep 27, 2004
    Retired
    Berlin, MD
    Thanks for the 800 number. I ordered a swithch, gasket, and arm & seal today. These are all the parts I need to repair the pump. But I thought of one other thing. Maybe I should replace the nut and gasket that go around the wire where it enters the motor. Is this something I could get locally at an electrical supply house or do I have to get it from Zoeller?
  11. sumppumppimp
    Sep 23, 2005
    You would be better off getting that from Zoeller since we have a special locking feature for the cord.
    Thanks,
  12. Bill MD
    Bill MD New Member
    Sep 27, 2004
    Retired
    Berlin, MD
    Thanks for the reply Zoeller. Can you tell me how much this item costs and if there is anyplace in the Washington, DC area where I can buy it?
    Thanks
  13. sumppumppimp
    Sep 23, 2005
    Part # 004322, list price is $1.70. You would have to call the 1-800 # ext 5 for customer service to find the local distributors.
    Thanks,
    ZP
  14. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Hey Zoellerpump,
    Are you affilliated with Zoellerpump directly? If so, I called them the other day. I was interested in trying to sell their Sump and Sewage pumps. They said the rep for my area was on vacation but would call in a week. It's been three. Do they sell so many pumps that they don't need any more suppliers?
    bob...
  15. sumppumppimp
    Sep 23, 2005
    We sell so many pumps it is unbelievable:cool: , but we could always use guys like you selling our products! What state and Zip code do you live in?
    I'm sorry, I just seen that you are in Florida. That Rep would be Target Marketing and there # is 407-245-7838, ask for Barry.
  16. Terry
    Aug 17, 2004
    If I could drop ship the pumps, I would be doing more.
    I used to sell about 15 sewage ejectoror packages a month.
    I need someone that I can work with on this
  17. sumppumppimp
    Sep 23, 2005
    Terry, I am not sure how this actually works out since I am in the Technical depatment. What you would have to do is talk to our customer service at 1-800-928-7867 ext 5 and ask them how that would work or even call your area REP, if you do not know who that is, ask customer service when you call them.
    Thanks,
    ZP
  18. speedbump
    Jul 15, 2005
    Riverview, Fl.
    That number doesn't work Zoellerpump. Is it the correct one 407 245 7838?
    bob...
  19. sumppumppimp
    Sep 23, 2005
    407-688-9696 is the new number, sorry about that.:eek:
  20. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Thanks ZP.
    bob...
  21. sumppumppimp
    Sep 23, 2005
    Hope it helps!
    ZP
Similar Threads: Best Sump
Pumps and Tanks Well Forum & Blog. Water is life. best replacement submersible sump pump Sep 29, 2007
Pumps and Tanks Well Forum & Blog. Water is life. What is the best place for sump pump to discharge? Sep 11, 2007
Pumps and Tanks Well Forum & Blog. Water is life. sump pump - best gas powered backup power source option Jan 1, 2007
Pumps and Tanks Well Forum & Blog. Water is life. best sump pump? Jul 28, 2006
Pumps and Tanks Well Forum & Blog. Water is life. CSV Question - Best of Both Worlds Jan 3, 2017
