Best Submersible Pump?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Spade, Aug 27, 2008.
  1. Spade
    Spade New Member
    Aug 27, 2008
    Arkansas
    My well is going on 20 years and I will soon be needing a submersible pump. They are expensive. Should I buy the Bronze Gould like I have now or go for one of the cheaper plastic models? Maybe the twenty year life of my current pump answers my question.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Only the part you can see is bronze. All the moving parts of a Goulds are plastic like many of the other brands. There are some brands that have Stainless Steel impellers but, they are so thin that I don't think they will last any longer than the plastic ones. The motor is a very important part, and I don't think you can get a Goulds pump with a Franklin motor any more.
    I would look for a pump with a Franklin motor, like the one you have now. Check the prices at www.pumpsandtanks.com for a comparison. There is not enough difference in pumps to be paying more money for a particular name.
    Even the brand name pump companies make a low grade version to sell at the box stores. You need a contractor grade pump, and there are a lot of brands that are as good as Goulds.
  4. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    I agree with valveman and stick with the Franklin motor. Apparently Gould started producing motors and had a major falling out with Franklin. My supplier ultimately switched to AY MacDonald pumps to continue receiving the Franklin motor.
  5. Leaky Boot
    Leaky Boot New Member
    Jun 25, 2008
    Goulds
    We can ship you a bronze top Goulds with Franklin motor. 1 hp will cost about $550 with shipping included. Will also include a free splice kit. Google our website "Howard Backhoe and Supply" Thanks! GH
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    That sounds like a good price, on as good a quality pump and motor as can be had. However, it should be noted that the impellers in the Goulds pump are still plastic like most others, no matter if the top of the pump is bronze, Stainless Steel, or plastic.
    http://howardbackhoeandsupply.blogspot.com/
    I hope this is the correct link to Howards. If not, I hope Howard or "Leakyboot" will give us the correct link.
    Thanks
    Cary
  7. Leaky Boot
    Jun 25, 2008
    Plastic---
    Yep---plastic inside, like everything else. Only advantage to the metal top is you don't have to worry about cracking it when you screw something into it. Otherwise might as well be plastic too. Thanks, LB
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
    I agree the brass top is much better than the plastic. However, I have installed a lot of pumps with plastic tops. You just have to be a little more careful as you said. Did I get the right link for you?
  9. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    My 1hp 20 gallon per minute Betta Flo is $490.00 plus shipping. It also has a Franklin Motor and the suction and discharge end is Stainless as well as the motor. Be sure you get the right pump for your well, there are more than just one 1 hp pump.
    bob...
Similar Threads: Best Submersible
Pumps and Tanks Well Forum & Blog. Water is life. Who Makes the Best Submersible Pump? Feb 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Best internet supplier of submersible Grundfos for DIYer? Jun 9, 2015
Pumps and Tanks Well Forum & Blog. Water is life. The best deep well submersible pump and motor? May 31, 2015
Pumps and Tanks Well Forum & Blog. Water is life. What is the Best Brand submersible Well Pump (Made in USA)? Apr 4, 2014
Pumps and Tanks Well Forum & Blog. Water is life. 3 Inch Submersible Pumps Best Brand? May 15, 2013
