Best shower head for extremely low water pressure
Discussion in 'Shower & Bathtub Forum & Blog' started by beautyfish, Jul 10, 2012.
  1. beautyfish
    beautyfish New Member
    Jul 13, 2009
    Pennsylvania
    We have extremely low water pressure at the street: about 14 psi as measured by the water company guy. They are not obligated to do anything about it as long as we get water, and by the time it gets to my second story bathrooms, the pressure is pretty pathetic in the showers. The sinks and tubs are useable, but taking a shower is pretty miserable. Can anyone recommend the best shower head for extracting the most pressure out of a bad situation?
    Thanks,
    Jim
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Your water company guy may be right, but I would suggest exploring this. See what your neighbors have. A pressure gauge is cheap and easy to use. Household water pressure can and does vary, but 30 psi to 60 psi is considered within normal range. Could be more, but not necessary. 14 psi is really off the bottom of the chart. You have to have more pressure to get decent flow. You're getting all of the pressure available, but your problem is lack of flow. There's a problem somewhere and I suspect the water company is not giving you full information.
  4. jadnashua
    IF, and this is a big IF, you have adequately sized supply and it's limited ONLY by the pressure, then your best solution is a retrofit pump/storage tank. These are available in a pre-engineered package. It isn't all that big, and all you need is a little bit of room near where the water comes into the house and a place to plug it in. You cut the main line, run it into the pump and reconnect the other cut end of the pipe into the outlet of the small storage tank. The pump runs, fills the small tank with pressurized water, and stops. The tank is there so the pump doesn't need to run each time you might want to brush your teeth with a small volume of water. Only when there's an extended use that brings the pressure down by emptying the tank does the pump turn back on (such as filling a tub, taking a shower, or filling the washing machine).
    If you search the 'This Olde House' archives, they installed one in a house with this type of a problem, and you can see what's involved. Much easier to see it rather than talking about it.
    I thought that the utility is required to provide 'useable' volume AND pressure...15psi isn't, at least for us spoiled AMericans! I've lived in places in the Middle East that used gravity fed storage tanks on the roof that provided about that, but I'd not call them great (but better than carrying water!).
Similar Threads: Best shower
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Your Beach House Shower: Best way of preventing sand build up in drain Dec 19, 2014
Shower & Bathtub Forum & Blog Shakoolie: The Best Shower Beer Holder Dec 7, 2014
Shower & Bathtub Forum & Blog Best Zombie Defence for your shower Nov 4, 2014
Shower & Bathtub Forum & Blog Best Drain Choice for a Solid Stone Shower Base (Made in Indonesia) Jul 8, 2014
