Best options for 13 inch rough in and small space?
Discussion in 'Toilet Forum discussions' started by flintshew, Mar 12, 2012.
  1. flintshew
    flintshew Petroleum Engineer
    Mar 12, 2012
    Petroleum Engineer
    Denver
    New small bathroom. We are trying to leave room for shower door to swing past front of the toilet, and so keep space behind tank to a minimum (every inch helps). Rough in is at 13 inches, apparently due to floor joists. Can the Toto 14" unifit adapter be shortened to 13" by any chance? Love the Toto toilets-- Is there any combination of toilet and connectors that could result in toilet extending about 28" from wall?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    No, you can't alter the Unifit adapters. You will need a 12" toilet. You can peruse the space specs on Terry's site linked from the top of this page. Exact space requirements vary from model to model. In other words, a 12" toilet does not mean it will use exactly 12" from the wall to the center of the flange. They frequently will need less than the listed size, but never more. I think you can find several options that will work for you.
  4. Terry
    Aug 17, 2004
    The round front Drake would be 28" to the end of the bowl on a 13" rough.
    The horn is 2-58" and the drain is 3"
    We sometimes pull the bolts close to the wall and set the bowl farther back in the drain. If the flange is notched, we can use a repair ring over it to re-position the bolts.
    [​IMG]
Similar Threads: Best options
Toilet Forum discussions Floor Water Supply - What Toilet Options Are Best? Nov 30, 2015
Toilet Forum discussions Best HET options for a hotel? Jul 27, 2010
Toilet Forum discussions Best site to see Toto Toilet Options May 15, 2010
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Best complete, elongated, tall toilet under $200 Feb 6, 2017
