Best option for spa wiring
Discussion in 'Electrical Forum discussion & Blog' started by restorick, Dec 1, 2007.
  1. restorick
    restorick New Member
    Dec 1, 2007
    Folks,
    I've done a number of wiring jobs where everything was indoors and I only had to deal with romex.
    But running a circuit for a hot tub is throwing me for a bit of a loop. My investigation shows that I can't run romex inside liquid-tite, but I certainly can run that indoors.
    How would I best go about running this circuit? Do I get enough 6/3 romex and then strip off the outer insulation to run inside liquid-tite? Or do I setup a waterproof junction box outside where I change from romex to THHN?
    Sorry if this seems like a basic question, but installing a subpanel in my garage seemed to be a hell of a lot more straighforward than this project, and there's a ton of conflicting info out on Al Gore's internet.
    Thanks in advance for any advice,
    Rick
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    You need a disconnect 5' away from the hot tub, so at that junction you would have to use a wet location wire... not romex...
    You really do need to read through part IV. Spas & Hot Tubs within art. 680.
    NEC 2005 Link
    This link is probably better suited for you though...
    http://www.mikeholt.com/files/PDF/Pooldownload.pdf
  4. restorick
    Dec 1, 2007
    Chris,
    Appreciate the link. I'll read through code 680, and check with my local inspector to see if I need to do anything special to comply here.
    Rick
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Check out the 2nd link, it has pretty pictures, the section you want starts on page 656 of the pdf file, if you have any more questions just ask...
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    I did one for my son with 3/4" PVC conduit. The last few feet of flex was connected to the end via a terminal adapter and liquid-tite fitting. The inspector was happy with it all.
    I used #6 but if your load doesn't exceed 50 Amps you should be able to use #8 THHN/THWN with #10 ground. If you have a large 240 Volt heater (meaning low neutral load) you might be able to use #10 for the neutral. Compare that with Romex (NM) where you need #6 for 50 Amps.
  7. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    We sleeve the last few feet of romex all the time and although a violation (wet area) never EVER get called on it.
    To be compliant, change to thwn at a JB. This puts extra splices in the circuit and because I do a ton of troubleshooting, I'm not a big fan of extra splices.
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    So does that make it right? I speed once and awhile, it's still against the law...
    You need a disconnect anyways... do the job right, or don't do it at all...
  9. Alectrician
    Jun 15, 2007
    What's your point? Did I imply otherwise?
    Then.....drive the speed limit or don't drive at all.
    Don't start with me dude.:mad:
    You choose when you can safely break the law and I choose whe I can safely violate the code. Same thing.
  10. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I always say, follow your conscience--not the laws, rules, or codes.
    Here's some laws that are still on the books in some states. There's a million more where these came from:
    It is illegal for a driver to be blindfolded while operating a vehicle.
    Dominoes may not be played on Sunday.
    You may not drive barefooted.
    It is illegal to maim oneself to escape jury duty.
    It is illegal to impersonate a person of the clergy.
    Women are able to retain all property they owned prior to marriage in the case of divorce. However, this provision does not apply to men.
    Masks may not be worn in public.
    Putting salt on a railraod track may be punishable by death.
    Boogers may not be flicked into the wind.
    Bear wrestling matches are prohibited.
    It is legal to drive the wrong way down a one-way street if you have a lantern attached to the front of your automobile.
    Men may not spit in front of the opposite sex.
    Incestuous marriages are legal.
    It is illegal to wear a fake moustache that causes laughter in church.
    You must have windshield wipers on your car.
    You may not have an ice cream cone in your back pocket at any time.
  11. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    My point is, do you think it is the smartest thing to give bad advice on a DIY forum, especially since you know better? :mad:
    He might as well go to Home Depot and ask them...
  12. Alectrician
    Jun 15, 2007
    A) I didn't tell him what to do, only told him what I do.
    2) If it WAS advice, it's not bad advice. There is nothing mechanically wrong with it. It is a technical violation.
    I know more about this stuff than you and all the Home Depot guys put together so you are going to have to find another way to try and insult me..
  13. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    I'm not about to have a argument with someone who justifies doing non code complaint work...
  14. Alectrician
    Jun 15, 2007
    I'm glad we settled that then.:cool:
  15. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Oh boy. Here we go AGAIN.
    You may not be a fan of splices, but the rest of us here are not fans of NON-compliant work.
    This is not advice. I'm just saying how I would do it. :p
    You know what, make your splices bulletproof then. Or better yet, DON'T make splices. Do it the right way and run the NM to the disconnect (if it is mounted on the house) and go from there with THWN in conduit and the maximum allowable 6' of sealtite at the tub.
  16. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Why not? It's fun! :D
  17. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    VA
    The conductors in romex are THHN THWN, The jacket is not aproved for use outside.
  18. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Yeh, too bad its not printed on the conductor to show the inspector... :D
  19. Alectrician
    Jun 15, 2007
    Read the post. Did I stutter?
    That's exactly what I would do but the last few feet of the run, out of the attic, down to the disco, sleeved in NM, would be non compliant. THEN I suggested changing to thwn to remain compliant. If I somehow suggested running the NMout of the building straight to the spa, my bad. I assumed from the original post that he knew that a disco was required and was inquiring about a method to change wire types.
    Got a code reference for that one? You can run as much sealtite as you want because OBVIOUSLY you would put a GC in it....unless you were and idiot.
    We all know that the wire in NM is thhn but since it's not marked, it's a technical violation. Sue me.
    Also, MC is not marked on the wire but don't you ever run it in emt, exposed down to a switch for example? What ever.
    Who elected you to be the head Dbag?
  20. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Your making such an ass out of yourself its not funny...
  21. jadnashua
    Look...if this was a pro hangout, I wouldn't see anything wrong airing dirty laundry and shortcuts you take that you believe are fine. This is primarily a DIY'er help site. Therefore, it behooves us to ONLY give code approved responses. If you want to give some advice that isn't up to code, give it in private. If you do post it, make sure you indicate the right way, or that this is not the approved way to perform that task.
    Name calling is pretty childish, too.
Similar Threads: Best option
Electrical Forum discussion & Blog what is the best grounding option Feb 11, 2009
Electrical Forum discussion & Blog Outdoor Outlets - Want The Best! Sep 3, 2015
Electrical Forum discussion & Blog Heating the floor of your home's elevator: What is the Best Way Dec 21, 2014
Electrical Forum discussion & Blog What box is best for Outside Wall Light Fixture in Existing T-111 to cut in? Jun 26, 2010
Electrical Forum discussion & Blog Best way to GFI protect can lights above a shower? Mar 27, 2010
