Best Float Switch
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ArayT, Jul 4, 2010.
  1. ArayT
    ArayT Member
    May 20, 2009
    Middle Georgia
    Who and what type float switch (mercury / magnetic??) is recommended for a sewage pump tank?
    Thanks
  2. ballvalve
    Dec 28, 2009
    northfork, california
    I buy from Graingers and they seem to last forever, especially if you use a "simplex" control box - which is just a relay that takes the pump load off of the switch contacts - then any switch might go millions of cycles, or to the rated life of the relay.
  4. ArayT
    ArayT Member
    May 20, 2009
    Middle Georgia
    Thanks for the responce. The problem because of the location and the existing wiring the switch will need to carry ther pump load. Its a liberty pump 1/2 hp 115 volt.
    Thanks rt
  5. hj
    Mercury switches are more reliable and last forever, if you can find them.
Similar Threads: Best Float
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Best Way to Splice Water Off This Sink Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Best Methods for Revealing Pipe Issues Inside Walls? Dec 15, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Best way to connect a 2" and 1.5" to a 3" DWHR unit? Nov 11, 2016
