Best Drill Bit for Electrical Wiring
Discussion in 'Electrical Forum discussion & Blog' started by Lakee911, Jan 17, 2008.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    What's the best type of drill bit for drilling through 2x material to pull electrical wire? Forstener? Spade? Auger? Twist? I've got lots of holes to drill and I'm tired of fooling with the spade bits which on a right angle drill always seem to bind. :(
    Thanks,
    Jason
  2. jadnashua
    None of the above...I can't remember the name, but try one with the screw point lead-in. Sort of like a twist drill with a wood screw on the front, it also has some of the features of a Forstner bit. It is designed to cut fast and is self-feeding because of the screw. Interesting to see what others have to say...
  4. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Just about every sparky i know, uses auger bits - I'm pretty sure that's what you're describing, Jadnashua?
  5. jadnashua
    Yep, that's it. Just don't hit a nail or screw with one. WHen they're sharp, they slice through really fast. Hit a nail, and it doesn't work well trying to tear the fibers at all.
  6. rdtompki
    rdtompki New Member
    Dec 21, 2005
    Iowa
    Some brands of self-feeding augers sold by electrical supply houses have nail-cutting capability. I'm not an electrician, but I've done a lot of rework. When you're drilling through a plate you can't always tell whether there is a nail in the way.
    Rick
  7. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    Electrical Contractor
    They're also called ship-auger bits.
    And you can get some that will go through nails with no problems.
  8. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    That's what I use too. Mine are getting old. Anyone know of a place to get them sharpened?
    Thanks
    Tom
  9. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    I use a Dremel tool with a small round-tip conical stone to sharpen mine.
  10. statjunk
    Jun 28, 2007
    Bob,
    For better or worse, I'm a generation X. I generally avoid sharpening things and rely on tools or professionals to do the sharpening. I'll have to find someone locally to sharpen them. I figured you'd need a special machine to sharpen those.
    I have two cases full of those things some that are pretty long. They are extremely useful.
    Thanks for the tip.
    Tom
  11. Lakee911
    Aug 23, 2005
    Columbus, OH
    I'll try to get a hold of some/one!
    Thanks for the advice!
    Jason
  12. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    I have about 20 of those in assorted sizes and lengths. I sharpen all of them myself. They come out as good as new. You just have to know how to sharpen them.
    I use a 4" angle grinder with a metal cutting wheel. NEVER sharpen the top. Always the cutting edge down into the throat.
  13. OscarG
    OscarG New Member
    May 11, 2007
    I picked up a set of Irwin Speedbor Max bits at BigBlueBox Store last summer to do a project. They are great! Three cutting edges, short enough so even w/o right angle drill I could go streight through joist on 16" center using battery power dirll.
    [​IMG]
    Check this link for Irwin Information
  14. 480sparky
    Oct 8, 2007
    Ask at a woodworking store.. they know people who sharpen saw blades, they can usually do these too.
  15. statjunk
    Jun 28, 2007
    Thanks for the tip Sparky. Will do.
    Tom
  16. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    No matter which bit that is choosen the proper driver for that bit is important.
    See the proper drive force by clicking here
  17. hj
    drill bit
    I sharpen mine with a file. Just takes a few strokes to get a good edge.
  18. Bob NH
    Oct 20, 2005
    New Hampshire
    I have one of those.
    Also have a breast drill, which is not used for lumpectomys.
  19. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I bought one of those (1-1/4") a few weeks ago, and it was so aggressive that my regular 3/8" drill could not keep it spinning until after I had drilled a pilot hole for the lead screw. From that point on, it was great until I hit a screw!
  20. jadnashua
    It would be a rare 3/8" drill that was rated to cut a 1-1/4" hole. Those bits are aggressive and will require a lot of power.
  21. leejosepho
    Nov 23, 2006
    This drill motor can usually handle just anything I can get in the chuck, but yes, this latest drill is a bit too much unless I use a pilot hole to wing it a bit!
Similar Threads: Best Drill
Electrical Forum discussion & Blog Outdoor Outlets - Want The Best! Sep 3, 2015
Electrical Forum discussion & Blog Heating the floor of your home's elevator: What is the Best Way Dec 21, 2014
Electrical Forum discussion & Blog What box is best for Outside Wall Light Fixture in Existing T-111 to cut in? Jun 26, 2010
Electrical Forum discussion & Blog Best way to GFI protect can lights above a shower? Mar 27, 2010
Electrical Forum discussion & Blog Best undercabinet lighting Oct 5, 2009
