Best Connection Method for PE pipe to rigid PVC?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Dennis47, Jul 2, 2013.
  1. Dennis47
    Dennis47 New Member
    Jul 2, 2013
    Arizona
    My first post. Our 35 yr old house is built on a rocky slope and has a black flexible water line, probably polyethylene (PE), from the meter to the house (about 100 ft.). We had the shut-off valve at the house end replaced last month and the plumber double-clamped the poly pipe over a Sch 80 PVC nipple threaded into the valve. This connection is in shallow dry well in the patio slab, and the end of the poly just barely makes it past the well wall so there isn't much to work with. The new connection is already leaking past the clamps. The system is under about 80 pound pressure. Before the new valve installation, the poly connection was tight and dry. Seems to me there must a better method for making this connection that I can ask the plumber to use; perhaps a compression-type fitting. Suggestions?
  2. hj
    A "barb fitting" is the proper thing to insert, NOT a "smooth" sch. 80 nipple.
  4. Dennis47
    Dennis47 New Member
    Jul 2, 2013
    Arizona
    With hose clamps? Is that all I need?
  5. Terry
    Aug 17, 2004
    It should have a barbed fitting and two hose clamps.
    I like brass, though those are normally only getable at a plumbing supply.
    The box stores are too cheap to carry what the plumbers use.
    Connecting poly with a barbed fitting requires some space to work with. Sometimes a union is handy in a tight space.
  6. Dennis47
    Dennis47 New Member
    Jul 2, 2013
    Arizona
    Plumber hasn't come back yet; I reported the leak Monday. I'll ask him to replace the PVC fitting with a brass barb if he can. My concern is that if he has to cut the nipple out of the poly, he'll have to break up the patio slab to get to a new clean end. Would you add the union on the rigid side just to gain some working room?
Similar Threads: Best Connection
Plumbing Forum, Professional & DIY Advice Best Pex Manufacture for Cinch Connections? Feb 7, 2016
Plumbing Forum, Professional & DIY Advice Best way to fix a non-leaking connection that looks bad Jan 9, 2012
Plumbing Forum, Professional & DIY Advice Best sealant for connection to in-wall drop ear elbow - Teflon tape or thread sealant Feb 7, 2011
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Best Way to Splice Water Off This Sink Jan 5, 2017
