Best Cleaner/brush for Toto Sanagloss?
Discussion in 'Toilet Forum discussions' started by cwooden82, Oct 26, 2010.
  1. cwooden82
    cwooden82 New Member
    Oct 26, 2010
    Keizer, OR
    Hi - after much reading have decided to buy a Toto Drake II to replace my ancient toilet (house built in '55, I think it's the original - has 4 bolts instead of 2) At first was going to cheap out - $ being pretty tight- and get a cadet or a Niagara. They had both of these installed in the ladies rm at my local plumbing shop, they let me stay in there and do flush tests. ;)Not being totally happy with the results, ( they both failed the pepper test ) decided to get out the card and go for the double cyclone flush with SG. I want to make sure to take good care of the finish - what do you recommend for cleaning inside/outside?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The AS Cadet would probably work OK as long as it wasn't defective. Pros like Terry and Redwood report many factory defects. The Niagara is really bad news, so it's good you stayed away from that one. Two of the four bolts on the old one go into the floor. The other two into the flange. You are spending a bit more for the Drake II, but you are getting a better toilet. I'm not sure what to use, but I do not you want to stay away from abrasives that will damage the Sanagloss, and are totally unnecessary on the exterior anyway. Your dealer should be able to recommend a good product and may even sell something. Hang around the forum, there will likely be some good suggestions.
  4. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    I have had a Toto Carlysle with Sani-glos for about ten years. I use Simple Green (diluted about five to one) with a plastic bowl brush (not a brush with a twisted wire holding the bristles) for general cleaning. I also disinfect with about a half-to-full cup of cheap bleach swished around and left for ten minutes maximum. Flush two or three times after the bleach treatment. About once a month pour some bleach through the overflow tube in the tank to disinfect the rim passages and holes. Follow this with two or three flushings after ten minutes.
    http://terrylove.com/pdf/cefiontect_instructions.pdf
    • Use a mild dish detergent to clean your lavatory.
    • Use a gel-based toilet bowl cleaner.
    • Use a soft cloth to clean your lavatory.
    • Use a soft-bristled plastic brush to clean your toilet.
  5. cwooden82
    Oct 26, 2010
    Keizer, OR
    The Cadet didn't have a good bowl wash, left pepper on the bowl even after a few flushes - read about some fixes having to do with reaming the holes out with a clothes hanger - no thanks. Don't feel I should have to fix a brand new fixture. The Niagara cleaned the bowl but didn't get rid of all the pepper - there was still some swirling around in the water after a few flushes.
    Furd - thanks for tips.
Similar Threads: Best Cleaner/brush
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Best complete, elongated, tall toilet under $200 Feb 6, 2017
Toilet Forum discussions The myst of the best toilet Feb 3, 2017
Toilet Forum discussions Best American Standard 12" Toilet for 11" Rough In Jan 2, 2017
Toilet Forum discussions Tiny half bath .. what is best toilet for my WC? Nov 11, 2016
