Best caulking for acrylic shower base
Discussion in 'Shower & Bathtub Forum & Blog' started by dirtmover, Sep 26, 2010.
  1. dirtmover
    dirtmover New Member
    Feb 16, 2007
    Ontario
    I recently installed an new shower with acrylic base and have been having terrible problems getting the caulk to seal at the base. It just does not want to stick to the acrylic and water seeps underneath it. The first application was made immediately after removing the plastic protective film so I assumed it was spotlessly clean. After a few days water was seeping under the glass and from the corner where the aluminum supporting rails meet the glass. I removed the silicone and throughly cleaned with isopropyl alcohol and re-caulked. Again after a few days it had detached again. I have been using GE silicone II and it has absolutely no problems sticking to the tiles, glass or aluminum rails but just doesn't want to stick to the acrylic base :confused:. Any ideas why or suggestions for a better product that will stick properly to the acrylic base.
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Does your pan flex much?
  4. dirtmover
    Feb 16, 2007
    Ontario
    There is very little to no flex. I emailed the manufacturer and here's the response I got:
    Hi,
    Acrylic has no porosity, that is why silicon doesn't adghere to it.
    Use masking tape and leave approx 1/4" of acrylic...use a fine sand paper to scratch the acrylic surface...then the silicon will adhere.
    Thank you
    Interestingly the installation instructions don't mention anything about this and unlike other pans I have since looked at does not have a raised edge that would have prevented water seeping over the edge in the event of caulking failure.
  5. jimbo
    jimbo Plumber
    That is interesting. But silicone will stick to glass. I wonder what is different about acrylic?
  6. jadnashua
    The acrylic could still have some mold release on it, which would make it tough to stick anything to it. Also keep in mind that some of those caulks, while they may get a skin on them fairly quickly, take up to a week or more to actually cure. Wetting them before full cure will cause them to fail.
  7. dirtmover
    Feb 16, 2007
    Ontario
    OK, I found it. The stuff is called Lexel and it sticks like sh** to a blanket. Once I knew what to look for a quick Google search reveals that it is highly rated for this type of application but unlike silicone doesn't have a huge market penetration. Unfortunately up here in Canada I could only find one source locally and only stocking small tubes of clear - I would have preferred white but clear is better than a leak.
    So far so good but only time will tell how is stands up.
Similar Threads: Best caulking
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Best bathroom vent fan with light? Jun 16, 2016
Shower & Bathtub Forum & Blog Best soffit vent w/ anti-backdraft, for bathroom vent fan? Jun 16, 2016
Shower & Bathtub Forum & Blog Best option for shimming Cambridge tub level Sep 30, 2015
Shower & Bathtub Forum & Blog What kind of tile is this and best way to clean the rust? Sep 14, 2015
