bemis tank
Discussion in 'Toilet Forum discussions' started by teddy75937, Nov 1, 2011.
  1. teddy75937
    teddy75937 New Member
    Oct 31, 2011
    TX
    Will a Bemis toilet tank fit other toilet bowls
  2. jimbo
    jimbo Plumber
    Bemis makes toilet SEATS. Never saw a Bemis TOILET.
    Nonetheless, toilet tanks and bowls are made as a SET. It is a mistake to try to mix brands, or even to mix models within a brand that are not specifically listed on the spec sheet as a set. The next thing you get into in any attempt to replace a tank or bowl....how old is it? Was it 3.5 gpg or 1.6 or 1.28? Is it a regular 2" flush valve size, or a jumbo? Gravity or power flush? Rim flush or siphon jet???
    It's a jungle out there!
  4. hj
    IF it has the correct measurements, i.e., center outlet to front of the tank center outlet to the rear of the tank, distance between the mounting bolts, AND water capacity, it SHOULD, but even then there could be some anomality which would cause it to not work. BUT where did you find a "Bemis" tank, since they usually only make toilet seats?
Similar Threads: bemis tank
Toilet Forum discussions Bemis Whisper Close StaTite toilet seat doesn't cover bowl Jun 7, 2015
Toilet Forum discussions Vespin II & Bemis NextStep seats Sep 5, 2013
Toilet Forum discussions Which Slow Close Seat for Drake II (Toto vs. Bemis) ? Jun 29, 2012
Toilet Forum discussions Toto slow close seat VS Bemis slow close seat for Toto Promenade Apr 20, 2011
Toilet Forum discussions Bemis toilet performance Jan 10, 2006
