Bell&Gossett 100 Series Repair
Discussion in 'HVAC Heating & Cooling' started by justin_24, Oct 13, 2008.
  1. justin_24
    justin_24 New Member
    Oct 13, 2008
    I have a home with boiler heat. My circulator pump has been making a lot of noise lately. I bought a set of motor mounts for the electric motor on the circulator. I was hoping someone could clue me in as to what kind of mess I'm getting into if I decide to do this myself. It seems pretty straight forward, and I do have some mechanical experience, but not with eletrical motors or pumps. The circulator is a Bell & Gossett 100 series, I already got the proper mounts from a B&G site. I just have to take the pump apart and replace the mounts on each end of the motor. Anyone have any tips? Or perhaps a quick walk through?
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    If the circulator is making a lot of noise it's probably the coupling between the motor and bearing assembly. The B&G coupling is a two piece affair with 4 little springs that connect the two pieces. They wear out and break. Changing the coupling is as easy as removing the 4 bolts that hold the motor to the bearing assembly and backing off two allen screws that attach each half (one to the motor, one to the bearing shaft. Re-assemble and oil the bearing assembly. If it's not the coupling the bearing assembly itself could need replacing and that's a bit more of a job as the pressure needs to be relieved from the boiler.
  4. xroad
    xroad New Member
    Oct 12, 2008
    Where Do I Find Parts
    Over the last 20 years, the circulation pump in my mother's house was replaced 2X. Now I need the 4th one. The price had increased over the years. I can take it apart and take the guts out. Where can I find replacement parts? It had got to be cheaper than buying a new pump.
  5. hj
    pump
    You need a new bearing assembly, impeller, and coupler. The motor mounts will eliminate wear on the coupler because of misalignment, and the other parts will rebuild the pump. We can get the parts at many places, but none of them sell to the general public.
  6. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    If you need an new bearing assembly you might as well pull the whole circulator and replace it with a Taco 007 or a Grundfoss. probably cost less than the bearing assembly and will run for years with no service.
  7. justin_24
    Oct 13, 2008
    You can get parts for B&G products here.
    www.simplyplumbing.com
    That's where I got the motor mounts.
    This link will take you to the B&G Literature page, where you can choose from many options to find part numbers and even find drawings of pumps and other products.
    http://www.bellgossett.com/BG-Literature-English.asp
  8. justin_24
    Oct 13, 2008
    Does the Taco 007 have the same flow as the B&G 100 series? Is it basically a straight swap? Same electrical, same dimension for the flanges, etc... or am I going to have to have someone come in and do an install if I decide to swap it out. I'm still running the same pump that has been on the boiler since it was installed in 1957. So I'm guessing I might as well replace it.
  9. jadnashua
    Taco makes a huge variety of pumps. The 007 is a commonly used one in residential heating systems. If you can look up the specs for the one you have, you can find an equivalent one on Taco. As in the Taco, the series of the one you have come in numerous versions.
    That series of Taco pumps are designed to remove the motor and reuse the pump body. Not sure of the relative prices - sometimes parts cost as much as a new one.
    While possible, I doubt the flanges would line up. You might get lucky.
  10. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The 007 is a direct swap for a b&G100 series, even the flanges line up. Flow rates are very near to each other and should be no problem in a residential application.
  11. justin_24
    Oct 13, 2008
    Awesome, that's what I like to hear. I'll be checking into a 007 then. Thanks for everyone's help.
  12. xroad
    xroad New Member
    Oct 12, 2008
    Taco Price
    I found the boxes containing 2 of the previous circulation pumps. One box, my father wrote the price on it, it was $250. Seem kind of high for that pump 16 years ago. Few months ago, I saw a circulation pump, I think it was the 007, at Home Depot. I recall it was around $150. That seeems high to me also. The pump I bought 7 years ago ... don't remember it was that high. Maybe I just don't remember.
    So, where is the low price place i can get them?
    Update: I just looked into simplyplumbing.com Taco 007 cartridge is $55, great.
    Plus shipping and tax $70.
    Is the cartridge that usually fail? I took att the guts out of the pump, I have no idea what failed.
  13. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I don't pay anywhere near that for a 007 but then I'm not a homeowner and I refuse to step through the doors of Home Depot or Lowes for any reason. If they had the last 007 in a thousand mile radius I would go do something else.
  14. hj
    Pump
    A heating system can use a cast iron body pump, it does not need a stainless steel or brass body. Armstrong pump parts are the same as B&G and are usually less expensive.
  15. xroad
    xroad New Member
    Oct 12, 2008
    So, what is a home owner (me) to do? I suspect my local plumbing supply store would have a lot higher price.
  16. xroad
    xroad New Member
    Oct 12, 2008
    Home Depot, Lowes, or local plumbing supply store ..... it's not like they have a broad ranges of choices. I have to buy whatever they have, at whatever price they ask. Well, no body HAVE to. I'm just just "shlub" that's just trying to save a few dollar and do this on my own, on the job training as I go. At some point, the project is bigger and more pain than I can handle and to make it painless, I have to throw money (give up)at it to end it.
    Where do I find them?
  17. xroad
    xroad New Member
    Oct 12, 2008
    at simplyplumbing.com
    Cartridge $55
    Pump without flanges $68
    Not a whole lot of difference between the repair parts and a new pump.
    Flanges ..... those are the mounting thingies at the two ends of the pump, right?
  18. justin_24
    Oct 13, 2008
    http://www.pexsupply.com/product_dtl.asp?pID=1983&brand=Taco&cID=289
    It's 59.99 for the whole pump. I contacted them to make sure it wasn't just the body w/o the cartridge. Total with shipping is 70. Ordered mine today.
    When I need things like this I tend to use the "shopping" option on google search. It has ratings for the websites that come up and finds the lowest prices, sometimes it ends up being an auction, sometimes it's a website. Hasn't really let me down yet.
  19. xroad
    xroad New Member
    Oct 12, 2008
    Thanks. I understand business have to make money. I am a gung-ho capitalist myself. So I excercise my full right to buy or not to buy with no bitching and moaning about someone "overcharging". Thanks God for te internet that allows cheap ass guys like me to find the lowest price. I'll leave the other guys that "can't stand the pain" to pay the higher price. I am amaze at the big difference between the low price and the high price for the same product. My father probably bought his pump 16 years ago from the local plumbing supply store without question. I am sure he would have spent a lot more if he call in someone to replace the pump.
    THANKS AGAIN.
  20. xroad
    xroad New Member
    Oct 12, 2008
    Taco 007 F4 or Taco 007 F5 ?
    Taco 007 F4 or Taco 007 F5 ? The two broken pumps I have are F4. The label said 1/25 HP. What is the difference?
  21. justin_24
    Oct 13, 2008
    The link I posted was for the 007-F5. I don't know off the top of my head what the difference is. You'd have to do a little searching to find out. Probably different amperage, flow, and maybe different physical size as well.
Similar Threads: Bell&Gossett Series
HVAC Heating & Cooling Honeywell 9000 Series Thermostat Installation Help Apr 19, 2016
HVAC Heating & Cooling Burnham Gas Boiler-Series 2 (model B) Oct 13, 2014
HVAC Heating & Cooling Weil-McLain GV-5 Series 1 gas boiler lockout Jan 23, 2013
HVAC Heating & Cooling Weil-McLain Ultra 80 series 2 Boiler failed Sunday Jan 3, 2013
HVAC Heating & Cooling Question regarding diagnostic code on recently installed York GY9 series gas furnace Feb 9, 2009
