belches out brown water
Discussion in 'Water Softener Forum, Questions and Answers' started by pitterpat, Jun 29, 2013.
  1. pitterpat
    pitterpat HandyWOMAN
    Jun 25, 2005
    A HandyWOMAN service..."Why hire a handyman when y
    Indianapolis
    I notice that some times I have brown water in my toilet bowl, it teams tha only this toilet gets the brown water (2 toilets in house). I am on a well with a water softner. I have lived in the house for 18 mons. before that it was vacant for about 2 yrs (owner went to assisted living she was 88 and original owner for 55 yrs). When I originally moved in it took me almost a yr to figure out how to get the system to work correctly (1st place with well) and to get the rust out of the system. I poured some stuff in the brine tube to cleaned the brine and manually regenerated it 2 times.
    Why am I getting this brown water in the toilet (probably once a week)?
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Do you have galvanized plumbing? Is the toilet used regularly? Are there other toilets?
  4. pitterpat
    Jun 25, 2005
    Indianapolis
    yes galvanized. 2 toilets, I figured out that the one with galv. pipes is belching the brown water, the other one has pvc pipes running to it.
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Well, then. A solution suggests itself...
  6. pitterpat
    Jun 25, 2005
    Indianapolis
    Not really, it seems to be on the day that the water softer regenerates is when the toilet water in that toilet only is brown. tks
  7. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    That suggests that air is getting into the softener during the brining stage due to a faulty float in the brine pickup.
  8. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    One has not said what type of softener is in use, that would help in figuring out what steps to take place for a correction.
    First idea that comes to mind with the dis-colored water the morning after a regen or cleaning is that the steps in the cycle are not long enough to
    properly clean the risen bed in the softener and that some changes are going to need to be made to the control.
  9. Gary Slusser
    Retired
    If the brown water is not present at all fixtures, then the cause is not the softener, it's a specific galvanized pipe dumping its load of built up rust in it. So... start using a different toilet for like a few weeks and see if that toilet has the rusty water problem the morning of a regeneration. If it does then it is the softener, if not, it is the plumbing. The cure and an overall help would be to get rid of all the galvanized pipe and nipples. Another cause may be using water while the softener is regenerating.
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    The brown water is likely rust from the piping, but the belching could be caused by air trapped in the softener. Air may take the path of least resistance which could very well be the toilet. The toilet could also be the first point of use for water after the regen.
    When air is combined with water, the water has less friction loss and so can accelerate through the line, stirring up what would otherwise not be stirred.
  11. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Also, the OP did not say what kind of pressure tank is on the well system. If it is a hydro-pneumatic, it is possible that the AVC is not working right to expel surplus air. This air could be leaving the tank during the backwash/regen. If the toilet flapper leaks, the air and rusty water could enter the line during the backwash/regen.
Similar Threads: belches brown
Water Softener Forum, Questions and Answers Brown water right after softener regeneration Jun 17, 2016
Water Softener Forum, Questions and Answers Culligan Super S with yellow/brown water Aug 11, 2013
Water Softener Forum, Questions and Answers Brown water morning after regeneration cycle Nov 10, 2012
Water Softener Forum, Questions and Answers Iron- brownish red water stains in and on fixtures Dec 14, 2010
Water Softener Forum, Questions and Answers Cold water suddenly brown Nov 14, 2010
