beckett oil burner:14yr, w/ tankless coil
Discussion in 'HVAC Heating & Cooling' started by lllowwin, May 15, 2007.
  1. lllowwin
    lllowwin New Member
    May 15, 2007
    beckett oil burner: Fuel seep below squirrel cage
    Trace dynamic oil seep @ burner case below squirrel cage. Will soak a cup of
    'oil dry' in one week. Squirrel cage dry, no apparent leaks gun assy. Webster M34DJ3 pump shaft source ? Online source for repl. pumps ?
Similar Threads: beckett burner14yr
HVAC Heating & Cooling Beckett Aquasmart Dec 8, 2014
HVAC Heating & Cooling Bad motor on my Beckett AF? Dec 27, 2013
HVAC Heating & Cooling Beckett Oil Bruner Leaking Oil From The Bottom Of The Plastic Case ??? Mar 1, 2011
HVAC Heating & Cooling Beckett Blues Nov 11, 2009
HVAC Heating & Cooling Intermittent ignition on W-M boiler, Beckett AF oil burner Dec 2, 2008
