Bathtub water flow rate question
Discussion in 'Shower & Bathtub Forum & Blog' started by texcollins, Mar 22, 2008.
  1. texcollins
    texcollins New Member
    Mar 22, 2008
    Texas
    I need to put a faucet valve in my bathtub and have been presented with two choices, either a 14.9 GPM@45 PSI or a 7.2 GPM@45 PSI. Can anyone tell me what a standard bathtub flow rate is? There is about $150 difference between the two choices and I'm wondering the flow rate in a typical bathtub is so I might have an idea how to compare. Thanks!:confused:
  2. jimbo
    jimbo Plumber
    One question would be what size pipe you have feeding the tub, and at what length from the main/water heater. 1/2 inch pipe will not deliver 14 GPM, without way too much pressure drop. You would have a water velocity of 14 feet per minute ( way too much ) and a pressure drop of 22 psi in 40 feet.
  4. jadnashua
    As noted, the biggest thing is what size are your supply lines? My guess is that the higher flow rated one expects 3/4" supply lines, and you won't get that flow unless they are that big.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The larger flow tub fillers are primarily for large tubs. Yes the supply would have to be there.
Similar Threads: Bathtub water
Shower & Bathtub Forum & Blog Bathtub 3 Handle Diverter Sprays Water Sep 28, 2016
Shower & Bathtub Forum & Blog Waterproofing bathtub cement backer board Jul 6, 2015
Shower & Bathtub Forum & Blog Freestanding bathtub in shower room (wet room) waterproofing drain ? May 21, 2014
Shower & Bathtub Forum & Blog Shower and Bathtub Do Not Have Cold Water Aug 14, 2013
Shower & Bathtub Forum & Blog Bathtub hot water faucet - no water comes out Mar 19, 2011
