Bathtub/Shower Valve distance to Tub Spout
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BobL43, Apr 11, 2011.
  1. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Hi,
    I recently bought a new Delta Intuition bathtub and shower valve package complete with the tub spout and shower head. The installation instructions say that the distance from the bottom of the valve body to the tub spout should be 8 to 18 inches. I am using this new setup to replace an older Delta valve body installation where the tub spout is slightly less (about 5 inches) below the valve body.
    I was just curious why they would spec out the distance other than just for the convenience of having
    the tub spout and valve body in "comfortable" positions. The tub spout seems at the correct height above the tub, and the valve is easy to reach as it is whether taking a shower or bathing.
    Thanks:confused:
  2. hj
    They err on the conservative side so the spout and valve trim plate do not interfere with each other.
  4. jadnashua
    The same valve supports many different trims...so, as mentioned, to ensure any one will fit, they define a minimum separation.
  5. BobL43
    Mar 25, 2011
    Long Island, NY
    Thank you gentlemen:D
Similar Threads: Bathtub/Shower Valve
Plumbing Forum, Professional & DIY Advice Water Damage in wall behind bathtub/shower in Master Bath Jan 15, 2017
Plumbing Forum, Professional & DIY Advice bathtub/shower drain Jan 10, 2012
Plumbing Forum, Professional & DIY Advice leaking behind bathtub/shower tiles Aug 19, 2008
Plumbing Forum, Professional & DIY Advice Basement Bathtub/Shower Venting Dec 19, 2007
Plumbing Forum, Professional & DIY Advice Is anyone familiar with Swanstone solid surface walls for bathtub/shower walls? Aug 25, 2007
