Bathtub Replacment
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Yourpersonalhandyman, Jun 16, 2006.
  1. Yourpersonalhandyman
    Yourpersonalhandyman Junior Member
    Jun 16, 2006
    I am in the process of re-modeling my bathroom. I noticed that I would need a new left-hand tub that, for the sake of making the install easier, would have to have the exposed side be an access panel. Can anyone reccommend a manufacturer who sells this type of tub ?
    My other option would be to cut out an access panel in my living room, which I would rather not do.
    Any assistance will be greatly appreciated.
  2. jadnashua
    Some of the manufacturers make aprons for their tubs. Sometimes on these, you need to buy a drop in tub, an optional tiling flange, and the apron. Once you get the tiling flange kit on, you can then treat it like a niche version with an integrated apron. WIth this type, you don't need to usually specifiy left or right, since they are symetrical, you can put the skirt on either side.
  4. joe4
    joe4 New Member
    Jun 16, 2006
    Installing bathtub and using pump to discharge water?
    How can I install a tub in my basement that has a large sewer drain real close, but don't want to jackhammer out c concrete floor for pea trap?
  5. Terry
    Aug 17, 2004
    Don't jackhammer, have a concrete saw cutter do it.
    No dust, nice clean cuts to pour to.
    You really do want the p-trap in the ground.
    There is nothing worse than falling out of a bathtub that has been raised to fit an above ground trap.
    The trap will need to be vented to prevent siphoning.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Not only do you not want to fall out of a tub that has been raised to accomodate a trap, the whole appearance will be that of a mickey mouse, jack-knife job. Do the job right to begin with and have an installation that will look good forever. I agree with Terry about having the concrete sawed, but actually a small hammer/drill will open the concrete fairly quickly, although not nearly as cleanly as the saw job.
  7. joe4
    joe4 New Member
    Jun 16, 2006
    couldI just put a pump behind the tub?
Similar Threads: Bathtub Replacment
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Water Damage in wall behind bathtub/shower in Master Bath Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Bathtub faucet help Dec 13, 2016
Plumbing Forum, Professional & DIY Advice Bathtub Overflow Repair Dec 13, 2016
