Bathtub replacement - what to do if overflow not centered over drain
Discussion in 'Shower & Bathtub Forum & Blog' started by loehrm, Dec 2, 2013.
  1. loehrm
    loehrm New Member
    Dec 2, 2013
    Austin,Texas
    I'm starting a bathroom renovation and have removed the existing alcove skirted fiberglass bathtub. It is 60 x 32.
    Currently I'm trying to find a replacement tub that I can install. My top contender is:
    http://image.mirabelleproducts.com/prodimages/mirabelle/specs/MIRED6032skirted_spec.pdf
    In measuring up based on the above specs, it looks like the existing drain in the floor will not line up perfectly with the overflow location on the above tub.
    The old tub had a 3 inch lip whereas the new has a 3 1/2" lip. It looks to me if I used a perfectly vertical drain kit i'd be about 3/4" inch shy of hitting the tub.
    How is this generally handled?
    1) Dig up drain in the floor and relocate?
    2) Customize a drain kit to include angles pieces?
    3) Use a flex drain kit?
    How would you guys approach this?
    Thank you,
    Mike
Similar Threads: Bathtub replacement
Shower & Bathtub Forum & Blog Replacement Bathtub Drain Questions Oct 25, 2014
Shower & Bathtub Forum & Blog Bathtub Faucet Replacement Nov 2, 2013
Shower & Bathtub Forum & Blog Help with bathtub replacement Sep 5, 2013
Shower & Bathtub Forum & Blog Bathtub replacement May 12, 2011
Shower & Bathtub Forum & Blog Replacement bathtub for 60x30 alcove Apr 24, 2011
