Bathtub redirect and concrete laundry sink!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lordoftheflies, Jun 18, 2013.
  1. lordoftheflies
    lordoftheflies Member
    May 28, 2013
    Tarrytown, NY
    Plumber redirected the 1st floor bathtub to the vent line today.
    Initially the problem was the bathtub kept backing up and everytime I plunged it I got food particles in the bathtub.
    I thought (as did the plumber) the reason was because of an incorrectly pitched 2" line coming out of the main sewer pipe (not sure what to call it but the toilet drains to it).
    I had just cleaned out that pipe as best I could but the tub didn't flow that much better.
    So.........after he did that (will post pics of that as well) and installed a mini vent for it, the dang concrete laundry basin started to leak. They had tried with might to unscrew a nut to no avail with pipe wrenches and I saw the pipes jiggling a bit and I'm pretty sure that's what caused it to loosen up.
    It was the end of the day and the plumber took off after replacing the metal trap with a pvc one. Left a bucket under it.
    So I decided to take a peek....and found that the whole mechanism for the drain for the laundry sink was indeed loose. (sink never leaked before but never had water backing up into it either)
    It's held in by 2 flat head screws and square nuts and it looks like the plumber's putty had tried up and cracked.
    As you can see by the stamp the basin was made in 1946! (same year the house was built)
    Took it all apart, cleaned off the chunks of dried putty, and used some thumb gum I had left over. I didn't have any plumber's putty handy.
    Is it ok to use the thumb gum? Or should I just get some plumber's putty and redo it? Seemed to make a good seal so I'm happy for now if you all think it's ok.
    Given its age the drain for the sink is doing ok - just a bit of rust. Perhaps I should paint it?
    Now, with regards to the redirect of the drain for the bathtub, this certainly didn't work out as well as I had hoped.
    Turns out now the damn laundry sink backs up with the water if you drain a full bathtub (that's how I saw the laundry drain leak).
    Does the laundry drain need its own vent like the bathtub?
    I do believe this indicates I must have some serious blockage between this connection at the sink and the house trap where the water main is....because the tub is draining at the same rate post redirection. So it wasn't the incorrectly pitched pipe....and now that I think about it some more that pipe was only about 3 feet long and a full bathtub of water would over come that slight incorrect pitch.
    At least I don't have to open up the line connected to the toilet to snake the bathtub any more.
    Hm. Now that I think about it some more....I'm going to fill the 2nd floor bathtub (we don't use it for baths often, only the 1st floor for the kids) and see how it drains. Showers in both are no problem.
    Any help is greatly appreciated.
    1. Original trap pipe was already rusted through!
    2. Final pvc setup for bathtub
    3. Laundry sink connected to vent and bathtub
    4. Date of manufacture of the laundry basin
    5. Final setup below the laundry sink
    Thanks.
  2. lordoftheflies
    May 28, 2013
    Tarrytown, NY
    Here are some more pics.
    1. Thumb gum
    2. Orig plumber's putty all dried up
    3. Side view of the trumpet attaching to the sink
    4. Original setup
    5. Mini vent used for the bathtub.
  4. lordoftheflies
    May 28, 2013
    Tarrytown, NY
    Ok just showered, filled the bathtub........watched it drain (I guess it's about the same rate as the 1st floor), ran downstairs to see if the laundry sink backed up and it didn't.
    And I can hear it come down the main sewer stack.....
  5. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    If the goo on the laundry tray washer leaks get a funnel washer, that is what it should have.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    After looking at the pictures I am truly at a loss for words. A "plumber" did that? Does he have a plumbing license?
  7. hj
    drain
    You show us the "mini vent" but where is it installed? From your pictures it looks like the tub overflow is connected to the drain line WITHOUT a trap. Funnel laundry drains always used putty for the seal.
  8. lordoftheflies
    May 28, 2013
    Tarrytown, NY
    On the road....
    The mini vent is connected to the "t" in pic 2. Of the first post right where trap is.
    The house is old 1947.
    There is no tub overflow. The tub does not have one and there used to be a stand alone one (from below you can see it is disconnected) and post renovation of the bathroom they just eliminated it ( before my time).
    I will keep a dry bucket under the sink but I will get a funnel washer anyways and some proper plumbers putty(people still use it right?)
    I will have to snake from the main stack to the water main. Something is definitely blocking.
    Judging my the amount of crap in the old laundry sink trap....I can just imagine.
    Do I need a mini vent for the laundry sink?
    Thanks for the helpful comments.
  9. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    The mini vent looks like it is on the tub, but the laundry tray seems to be wet vented between floors. A mini vent on the tray won't protect the trap from positive pressure.
    HJ knows what he is doing so putty must work, but where I come from a funnel washer is used (Kirkhill # G-81, Lasco # 02-3078 (bulk) or 02-3079 (carded), or equal)
  10. lordoftheflies
    May 28, 2013
    Tarrytown, NY
    Thanks Asktom.... I will procure a washer if this setup starts to leak. So far so good.
    As for the bathtub the plumber came back and redid it so that I have a trap I can take apart now if I have to.....
    and also added a cleanout in the PVC near the floor.
    He also snaked the 2" vent line while everything was apart and it must have been clogged up pretty bad because now a full bathtub flies down the PVC and doesn't back up into the laundry sink.
Similar Threads: Bathtub redirect
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Water Damage in wall behind bathtub/shower in Master Bath Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Bathtub faucet help Dec 13, 2016
Plumbing Forum, Professional & DIY Advice Bathtub Overflow Repair Dec 13, 2016
