bathtub overflow configuration?
Discussion in 'Shower & Bathtub Forum & Blog' started by jasaxon1900, Mar 29, 2012.
  1. jasaxon1900
    jasaxon1900 New Member
    Mar 21, 2012
    ontario, canada
    On the new waste and overflow drain that I am installing there are 3 possible configurations (direct, indirect down, and indirect rear). I am installing new dwv lines to the main stack so I can place the trap below in any location (open basement) so it is possible for me to use either the 'direct' or the 'indirect down' configuration.
    Is there one that performs better than the other? It would seem to me that the 'direct' would be preferable as the water is going directly down to the trap and out as opposed to horizontal and then down to the trap.
    Thanks in advance for all your help and advice!
  2. jadnashua
    If you get a clog, the most common way to snake a tub drain is to go through the overflow. This would only work with the indirect configuration. On most drains, you can't get the grid out of the drain without lots of trouble, but the overflow cap usually comes off easily.
  4. jasaxon1900
    Mar 21, 2012
    ontario, canada
    Thanks.
    The p-trap for the tub in the basement has a clean-out in it - does that matter?
Similar Threads: bathtub overflow
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
Shower & Bathtub Forum & Blog Need help picking a bathtub waste overflow (BWO)/drain Jun 17, 2016
Shower & Bathtub Forum & Blog Bathtub replacement - what to do if overflow not centered over drain Dec 2, 2013
Shower & Bathtub Forum & Blog Wye in bathtub overflow Feb 2, 2013
Shower & Bathtub Forum & Blog Modifying Bathtub Drain and Overflow Kit Dec 20, 2011
