Bathtub odor..from where?
Discussion in 'Shower & Bathtub Forum & Blog' started by LawyerRon, Dec 16, 2007.
  1. LawyerRon
    LawyerRon New Member
    Jan 24, 2007
    We get a bad odor from the bathtub only after someone takes a shower. It appears to be coming either from the drain, or the vent just below the spout. How does one go about getting rid of this? TIA
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Remove the hairball from the drain!
    have you got a pop up or grid strainer drain?
  4. LawyerRon
    Jan 24, 2007
    Tried that with no luck. I've put drain cleaner, acid, ect., down the drain and haven't solved the problem.
  5. MG
    MG New Member
    Jun 29, 2005
    Illinois - Near St. Louis
    Acid? Yikes.
    Are you sure there is a trap installed for the tub drain?
  6. LawyerRon
    Jan 24, 2007
    Well, I’m not an expert on this, but I assume it has a p-trap, if that’s what you’re referring to. It’s an upstairs bathtub.
  7. jadnashua
    the overflow can be a good source of accumulated crud depending on the type of stopper that is in the drain. Some have a tube that is raised or lowered to block the drain, and the opening can catch and hold hair and crud. If yours is that type, you may want to try to remove it through the lever and clean it up.
  8. LawyerRon
    Jan 24, 2007
    Yeah, I agree, I think it’s in the overflow tube. Any tips on cleaning it out? Mine has a round plate over it with a screw in the middle. The center post where the screw goes is in the way.
  9. jadnashua
    Post a picture...
  10. nadine
    nadine New Member
    Dec 11, 2007
    clean first bathtub drain. What kind of odor you feel. having smelt can be predicted from where it's coming.
  11. Redwood
    Dec 15, 2007
    Service Plumber
    Does your drain have a grid strainer or, a pop-up stopper?
Similar Threads: Bathtub odorfrom
Shower & Bathtub Forum & Blog Clawfoot bathtub gurgles Monday at 12:45 PM
Shower & Bathtub Forum & Blog How do I remove these bathtub skirt panels? Feb 16, 2017
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Bathtub Mortar - Should I be worried? Feb 13, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
