Shark77
I am tackling my first bathroom remodel and am a little stuck with the bathtub install. I am installing a Kohler archer 60"x30"x19" tub onto a post tension slab. The plumbing throughout the house is ABS and the Kohler drain is PVC. I cut out the previous tub's drain, then fit the Kohler parts onto the ABS using green ABS-PVC transition glue at the ABS coming out of the slab, and regular PVC primer and glue on the rest.
Although I dry fit the tub 3-4 times to get the fit just right, when I glued the drain, it ended up slightly higher than planned, and now I am having trouble getting the tub level because the drain is pushing up on the tub. I even layed down a mortar bed, but pulled it out because I knew the drain was blocking me from achieving level. Once I pulled the tub back out, I noticed the bathtub drain was pitched the wrong direction causing the water to drain slightly uphill-I know this is bad and will cause drainage issues down the road.
So I know I have to redo the plumbing. I think if I go a half inch lower everything will work out. I think the key is having about an 1/8th inch gap between the top of the tub drain rubber gasket and the bottom of the tub to force the proper 1/4" per foot slope. Am I missing something? I still have about 2" of ABS sticking out of the slab that I can attach a new sanitary tee to. If I chip out the concrete around the ABS I think I will get to the p trap, but don't think I need to go that far. Am I good using the ABS-PVC transition glue at the sanitary tee, or should I go with an ABS tee and pipes, then use proflex couplings to attach the tub drain and overflow PVC pieces to the ABS?
Also, when I pulled out the tub, I noticed the supports along the bottom were slightly cracked-should I return the tub to Lowes for a new one? The inside of the tub looks great-no cracking at all.
