Bathtub gurgles
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Master Brian, Oct 1, 2009.
  1. Master Brian
    Master Brian DIY Senior Member
    Nov 13, 2008
    Kansas
    My bathtub, which is a clawfoot tub - if that matters, gurgles when it drains. Is that normal? I can't recall if my other house's tub did this or not. Maybe a little, but this seems loud. It doesn't do this when anything else drains.
    The tubs drain is 2" PVC, it T's into a vertical 4" vent/drain stack, which drops about 1-2' before going into the main 4" sewer line. Above the "T" is cast, below is PVC. From what I can figure out there is nothing else dumping into this 4" vertical pipe. So it only serves the tub's drain and vent. The cast terminates the roof.
    Google searches seem to say gurgles are the result of a clogged vent, but they also seem to only talk about gurgling when trying to drain two fixtures at once.
    So, I wonder, is this normal due to the water draining really quickly through the 2" line or do I need to look into having the 4" cast iron vent section snaked.
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    You already picked up on that it might be because the water is draining too quickly. And since I am not there, and you describe your piping as definitely oversized, it makes sense that most likely the water is draining quickly enough to make a constant noise like a sink does...otherwise, if you are intermittent noises like bubbles coming up, then you probably have a clog.
  4. jimbo
    jimbo Plumber
    A clogged vent can cause OTHER fixtures on the line to gurgle, as their traps are siphoned, and a clogged drain can cause many symptoms.
    In your case, I gather that slow draining is NOT your issue? And is there a trap close to the tub?
  5. Master Brian
    Nov 13, 2008
    Kansas
    There is a trap about 12-18" under the floor below the tub. I wondered if it's too low, but there are other items obstructing it from being up further and it is basically horizontal, with slight slope to where it ties into the vertical drain/vent stack.
    As Basement Lurker suggested it is probably just draining too quickly, as there are no bubbles and nothing else gurgles as it drains and it doesn't gurgle when anything else drains.
    Is it actually possible for it to drain "too" quickly? There is one of those screw on cleanouts in the P-trap and water seems to be in there every time I check and I don't smell any odors.
    Thanks for the replies...
Similar Threads: Bathtub gurgles
Plumbing Forum, Professional & DIY Advice bathtub gurgles Feb 6, 2007
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Water Damage in wall behind bathtub/shower in Master Bath Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Bathtub faucet help Dec 13, 2016
