Bathtub fixture replacement
Discussion in 'Shower & Bathtub Forum & Blog' started by ASantibanez, Apr 30, 2007.
  1. ASantibanez
    ASantibanez New Member
    Apr 30, 2007
    I would like to replace the spout in my bathtub but have not done one before so want to make sure I go about it correctly. Right now the spout is not flush with the tub wall, so there is a space where I think water can get into the wall. I want to address this problem when I put on a new spout. When choosing a new spout, how can I make sure it will fit properly and be flush against the wall? Is there any kind of sealing material I need to use between the spout and tub wall to ensure water does not get through? Also, what steps are involved in replacing the spout? I am imagining I would just need to loosen and remove the old one and replace it with the new, but am not sure and don't want to get in over my head!
    Allison
  2. jadnashua
    Spouts attach in (typically) one of two ways - screw on, or push on. To remove a screw on, you literally unscrew it from the fitting. To remove a push on, somewhere on the under side, there will be a set screw which holds it to the pipe - loosen that and pull it off.
    If it is a screw on, getting it to tighten just where you want it requires careful measurement and a little finess.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Why not just caulk that little gap instead of replacing the spout. Even if it were flush, you would still need to caulk it. Use G.E. white silicone caulk for shower and bath.
  5. ASantibanez
    Apr 30, 2007
    Help! I have replaced the spout but now when I pull the diverter I get a leak out of the back of the spout (end closest to the wall).
    Thanks for the previous tips, unfortunately the gap before I think was a bit too big to seal with caulk, plus I wanted the new spout as the old one had a lot of hard water buildup and a diverter that didn't seal off completely.
  6. jadnashua
    Is it screw-on or push on? If it is screw on, you didn't put teflon tape on it or use pipe dope. If it is push on, you may have a bigger problem as the pipe may have been distorted by overtightening the set screw, and the O-rings can no longer seal because the pipe isn't smooth and round.
    Another though, if it was a screw-on, and was quite tight, you may have damaged the connection in the wall when you removed it.
Similar Threads: Bathtub fixture
Shower & Bathtub Forum & Blog Do you recognize this clawfoot bathtub fixture? Jul 19, 2009
Shower & Bathtub Forum & Blog replacing old bathtub and shower fixtures Jul 9, 2006
Shower & Bathtub Forum & Blog old bathtub and fixtures has no shower head Jul 25, 2005
Shower & Bathtub Forum & Blog HELP! Can't get bathtub drain fixture removed May 10, 2005
Shower & Bathtub Forum & Blog How to tighten bathtub brass insert Wednesday at 3:54 PM
