Bathtub Faucet Valve Stem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jsmitchell, Aug 2, 2008.
  1. jsmitchell
    jsmitchell New Member
    Aug 2, 2008
    I am trying to replace the washers in my bathtub faucets, but despite removing all of the nuts etc around the stem, I cannot remove the stem to get to the washer.
    It appears to be a regular compression set up, but once everything is off, the stem just spins, but cannot be removed. You can wiggle it up and down and even pull it to seat the washer, but I can't figure out how to get it out to replace it. Any suggestions would be greatly appreciated.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    You probably have just removed the packing nut. There is probably another one deeper in the wall.
  4. hj
    faucet
    What do you mean by "pull it out to seat the washer"? Is the hole in the wall large enough? Something inside it may have swollen or become displaced and you just have to pull harder. But do anything carefully, because if you break it and cannot get it out you will not have any water until you do. Pictures of the unit might help us see what your problem is.
Similar Threads: Bathtub Faucet
Plumbing Forum, Professional & DIY Advice Bathtub faucet help Dec 13, 2016
Plumbing Forum, Professional & DIY Advice Bathtub faucet, Help with identifying old trim Dec 1, 2016
Plumbing Forum, Professional & DIY Advice Reduced Water Flow in Single Bathtub Faucet Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Water leaking from the bathtub near the faucet Jul 27, 2016
Plumbing Forum, Professional & DIY Advice Bathtub faucet identification Jul 2, 2015
