bathtub drain question
Discussion in 'Shower & Bathtub Forum & Blog' started by congaman59, Jan 7, 2010.
  1. congaman59
    congaman59 New Member
    Jan 7, 2010
    ATL
    I have a tub with a built in drain shoe. The lever broke right behind the mounting plate. then as I was taking it out of the tub I lost he spring down the drain! Is this part something I should be able to find at Home Depot, or Lowes, or will I have to go to a Plumbing supply store to get it?
    I'm hoping it's not something that is part of the original bathtub, and is still available.
    I attached a picture of the part in question.
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    You can buy just the face plate and attach the existing plunger or get the complete assemble. Big box stores may have them either way.
    John
  4. hj
    drain
    The spring should not cause a problem, but if you can find a small magnet on a string and drop it down the pipe it will be retrieved. The overflow plate is a generic item, just be sure to use a brass cotter key to attach the clevis to it. If the new one comes with a steel cotter pin, reuse the brass one from your old drain.
Similar Threads: bathtub drain
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Drain Flange won't seal to bathtub Dec 21, 2016
Shower & Bathtub Forum & Blog Bathtub shoe drain too short Sep 15, 2016
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
