Bathtub Drain Problems
Discussion in 'Shower & Bathtub Forum & Blog' started by CTWeekendWarrior, Jul 8, 2008.
  1. CTWeekendWarrior
    CTWeekendWarrior New Member
    Jul 8, 2008
    Structural Engineer
    Enfield, CT
    The drain in my bathtub is leaking, so I tried to remove the drain in order to install a new gasket. When I tried to unscrew the drain the cross shaped piece in the bottom of the drain snapped. Now I have no clue how I am going to remove the broken drain. A trip to my local home improvement superstore yielded no help. If there is anyone out there who has had a similar problem, your advice would be much appreciated. Thanks.
    -CTWW
  2. resojoe
    resojoe New Member
    Jul 8, 2008
    CTWW, I had the exact same problem today...
    check this post out from a previous thread.
    good luck!
    Reso
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    That is the method I would use, only I would make 2 cuts on opposite sides to give more possible angles to chisel it around. You need to be careful to avoid damaging the tub.
  5. CTWeekendWarrior
    Jul 8, 2008
    Structural Engineer
    Enfield, CT
    Brilliant!
    That is pure genius! I'll give it a shot when I get home this evening. Thanks for the great info.
    -CTWW
  6. hj
    slot
    You have to remove the entire groove all the way to the outside. A single cut on the opposite side will allow it to be collapsed inward to close up the slot and then the piece will almost pull out without rotating, or at least rotate with your fingers.
  7. CTWeekendWarrior
    Jul 8, 2008
    Structural Engineer
    Enfield, CT
    Well, I got the drain out last night using the method resojoe suggested and it worked, although it took a significant amount of effort. I love how the photo shows a nice clean work surface - kinda misleading. It probably doesn't help that it has been 95% humidity the past few days here in Southern New England. I ended up cutting my thumb, fouling the threads on the old drain, buying a new overflow assembly, and assembling-disassembling-reassembling a few times, but after 4 1/2 hours, my tub drain is leak free!
    They don't call me the warrior for nothing.
    -CTWW
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Glad to hear of your success but sorry to hear of the injury incurred.
    I hate to bleed!:eek:
Similar Threads: Bathtub Drain
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Drain Flange won't seal to bathtub Dec 21, 2016
Shower & Bathtub Forum & Blog Bathtub shoe drain too short Sep 15, 2016
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
