Bathroom waste/vent piping [PICTURE]
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tbdub, May 27, 2010.
  1. tbdub
    tbdub New Member
    Sep 9, 2009
    Southern IL
    I am remodeling my bathroom. Is this an acceptable way to do the waste/vent?
    [​IMG]
  2. Terry
    Aug 17, 2004
  4. hj
    It's a good thing people do not try to be their own doctors or lawyers, or those professions would be in a world of hurt. But EVERYONE wants to be a plumber, because all you have to do is "put a few pieces of pipe and fittings together and the job is done". Your drawing does NOT vent the most important fixtures, the ones that really need them.
  5. tbdub
    tbdub New Member
    Sep 9, 2009
    Southern IL
    How about this?
    [​IMG]
  6. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    Lav is still not vented. You could normally connect the lav with a santee and bring a separate 1.5" vent off the top to vent it. You might also be able to arrange things and "wet vent" through the lav and have a single vent to vent the entire bathroom group. You have to see what plumbing code you are under and what is allowed. For instance, some codes require the vent for a toilet to be within a certain distance and others allow an unlimited distance to the vent for a toilet. There are also requirements on how far the vents for the other fixtures and be from their vents and these distances change depending on what code you are under.
    I also strongly recommend getting a permit and having this inspected. This a good 2nd check to make sure you have things correct and legal. Many people try to bypass inspections/permits to save $$, but that is really a bad idea in my opinion. It is worth a few bucks to make sure it is correct and legal.
  7. tbdub
    tbdub New Member
    Sep 9, 2009
    Southern IL
    sorry nukeman, i think i changed my picture while you were replying. Is the picture above your reply correct now? The lav and shower are both vented and the WC is wet vented through the 3" upstream to the 2" dry vent. Correct?
  8. Terry
    Aug 17, 2004
    Bring in the shower on the other side of the toilet with a wye fitting. A proper vent is downstream, not upstream.
Similar Threads: Bathroom waste/vent
Plumbing Forum, Professional & DIY Advice Basement Bathroom - Need Waste/Vent Help Aug 24, 2009
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Yesterday at 1:36 PM
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Tuesday at 11:20 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Sunday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Materials needed to PEX Bathroom Sunday at 10:01 AM
