Bathroom Venting Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Louie C, Apr 20, 2009.
  1. Louie C
    Louie C New Member
    Apr 20, 2009
    I have a 50 year old raised ranch. We have two bathrooms on the raised level right next to each other so that one has a window and one does not. It actually has the appearance that it was at one time one larger bathroom but, somebody added a bathroom to the master bedroom. The bathroom closest to the back of the house (with the window) was never vented at all. The hall bath was vented straight into the attic. Luckily, it doesn’t seem as though any damage was done. We have a very low roof and it would be nearly impossible to vent this to the soffit as I can not fit there and I am not very large. I am thinking of venting the two bathrooms to the gable side. It will be about a 15 foot run to the gable. My question is if I pitch the ductwork toward the gable, can I vent the two out of one vent. I'd rather not cut two holes into the side of my house. Much less have two vents within 4 feet of each other from the exterior view. I feel like if it is pitched on a slope over 15 feet, it would be unlikely for the moisture to work its way back to the other bathroom.
    Any help would be appreciated!
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    It all depends what the code allows at your location. In many locations the vent must extend though and above the roof.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Surely you can combine two vents but what is this about ductwork¿
  5. Louie C
    Louie C New Member
    Apr 20, 2009
    What I'm hoping to be able to accomplish is to have the ductwork run from both bathrooms seperately, and meet at a y or a T attachment to enter the 4 inch duct at the gable.
  6. Rich B
    Rich B DIY Senior Member
    Sep 13, 2008
    New Jersey
    I think the subject is about ducts for ventilation not a DWV vent........
  7. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    You'll have to check local codes on what's allowed, but as a practical matter, you can't join two 4 inch lines into one 4 inch line without a severe drop in performance if they are ever used at the same time. Any standard size less than 6 inches (round, or rectangular equivalent) will be a reduction when two 4's are fed into it.
Similar Threads: Bathroom Venting
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Venting a bathroom Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Wet venting layout for bathroom Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Help with Bathroom venting Nov 7, 2016
Plumbing Forum, Professional & DIY Advice Venting Bathroom Nov 1, 2016
