Bathroom ventilation
Discussion in 'HVAC Heating & Cooling' started by dhjnyc, Mar 5, 2007.
  1. dhjnyc
    dhjnyc New Member
    Mar 5, 2007
    New York
    I have an apt in a old new york building. The airvent in the bathroom has no fan and goes to the roof. It is a duct which is shared by all apts on my line. Can I add a fan to this vent? (I realize I need electricity). I just am wondering if it is possible to retrofit a bath vent (broan, nutone, panasonic etc.) and what are the possible problems?
    :confused: dj
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If you do , it is possible that the dynamics of the system could cause the odors and steam from your bathroom to be forced into a neighbors bathroom.
  4. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    alternatives to a fan in the bath
    Water vapor rises, and hotter air rises, so the vent may be doing an adequate job all by itself. Are you unhappy with the rate at which steam disappears? Is your bathroom musty and moldy? Does steamy air get into the other rooms? What are you hoping to solve, fix or improve?
    When air leaves the room through this vent, make up air has to come from somewhere. When steamy air leaves, "new" air comes from some other room. This would be through the crack under the door and through other openings.
    If you want to get rid of the steam sooner, and not let part of it flow into other rooms after you open the door, think of how you can arrange for more make up air to come into the bathroom, somewhere low. Improving that flow will displace more steamy air more quickly. Bringing in the make up air at a low height helps keep the hot air moving upwards more smoothly as a separate layer, instead of diluting it.
    david
Similar Threads: Bathroom ventilation
HVAC Heating & Cooling Bathroom Fan Ventilation Dec 19, 2010
HVAC Heating & Cooling Can a bathroom vent exhaust duct be TOO short? Jan 30, 2017
HVAC Heating & Cooling Radiant Floor Heat in Bathroom and other ramblings... Jan 7, 2017
HVAC Heating & Cooling AC vent and exhaust fan in same bathroom? Aug 12, 2016
HVAC Heating & Cooling Basement Bathroom HVAC Question Apr 17, 2016
