Bathroom vanity water trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BillM, May 26, 2008.
  1. BillM
    BillM New Member
    May 28, 2007
    Michigan
    Good morning all........I removed old bathroom vanity, and purchased a new, freestanding vanity.......Problem is: rough plumbing (1 1/2" water pipe) that comes out of the wall is too low to allow for a 'trap'? I cut out the back of the vanity to allow the pipe to fit into the vanity, but it (the pipe) only has 2 inches of clearance below it, to the bottom of the vanity.......Not enough room to allow for a typical 'trap'.......Any ideas on how to get around this, without raising the rough plumbing? Any trap adapters, or something? I'm a complete novice.......
    Thanks for any info...
    -Bill
  2. dwpecksr
    dwpecksr New Member
    Sep 27, 2004
    owner Dale's Plumbing Service inc
    Kansas
    can you also cut notch in the bottom of the vanity for the trap?:)
  4. BillM
    BillM New Member
    May 28, 2007
    Michigan
    I thought of that, as a last ditch option? I'd like to avoid that, since (1) would take away storage space within vanity cabinet, and (2) would cause exposed plumbing under the 'decorative' vanity......It would probably work, but would ruin the look?
    What is the purpose of the trap, anyway? i.e. Couldn't I just run piping from the sink drain, and elbow it off directly into the rough plumbing at something like a 75 degree angle? or, would that impede the water flow into the rough plumbing drain?
  5. hj
    trap
    Without getting into a class discussion of traps, siphonage, sewer gases, etc., suffice it to say you DO NEED a trap, and the solutions you are proposing either eliminate or negate the trap and its purposes. Either cut on opening in the bottom for the trap to hang into or raise the pipe. Those are the only two viable options to maintain the trap's integrity.
  6. BillM
    BillM New Member
    May 28, 2007
    Michigan
    Thanks, HJ
    ok.....it sounds like the quickest/easiest is to cut hole in bottom of vanity and, and move on from there......but......if I were to raise the height of the rough plumbing drain, how do I do that? The rough plumbing pipe runs horizontally through the studs in the wall, and then is positioned in its present location with 2-90 degree pvc fittings....(condo was built x 30 years ago?).......sounds like a plumbing project best left to a pro.......unless this is easier than I think, which I don't suspect to be the case......
    I think I'll go with option 1.......cut a hole in bottom of vanity, and run with it?
Similar Threads: Bathroom vanity
Plumbing Forum, Professional & DIY Advice Converting basement single vanity bathroom into double vanity. Have questions Dec 30, 2015
Plumbing Forum, Professional & DIY Advice Bathroom double vanity not draining Dec 18, 2015
Plumbing Forum, Professional & DIY Advice IKea wall mounted bathroom vanity install problem Nov 9, 2015
Plumbing Forum, Professional & DIY Advice Bathroom vanity supply lines under vanity? May 9, 2014
Plumbing Forum, Professional & DIY Advice Installation of shutoff valves for bathroom vanity - is this a reasonable idea? Apr 13, 2014
