Bathroom vanity replacement
Discussion in 'Remodel Forum & Blog' started by rburt5, Jul 21, 2014.
  1. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    I want to replace my bathroom vanity. It sets tightly between two walls that are 48" apart. This is not a high end remodel, and I would like to stay away from custom built cabinets. The problem is that 48" cabinets from the big box stores say they need a 49" top (for overhang?) Would it work if I ordered a 48" vanity top from somewhere? Or can I get a standard 49" formica vanity top and cut off 1/2" from each end?
  2. hj
    You do NOT need "overhang" if it is going between side walls. In fact that would be one thing you did NOT want. Buy the 48" cabinet AND a 49" countertop, the cut the 1/2" off each end.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If you want something that looks nice, a countertop specialty shop can make a vanity top any size.
    Caduceus likes this.
  5. queen50
    queen50 Member
    Mar 10, 2012
    Auburn, Washington
    You may be able to get a bargain on granite for
    For the size of top you need you may be able to get a good bargain at a granite supply place.
  6. jadnashua
    Many tops can be fairly easily cut to fit in there. Depending on how square the opening is, you might want to consider a slightly narrower cabinet, and then buy the prefinished matching filler pieces trimmed to fill in that small gap exactly. If you don't want or need drawers, it's not all that hard to just build a frame - there are a bunch of prefinished doors you could then put on it. Lots of choices, some of them depend on your skill levels and what tools you have. Something like a quarter-round trim can hide slight misfits if the walls aren't plumb or square.
    A granite fabricator will often have some remnants that could be used, but making the cutout for the sink (especially if you want an undermount that needs to be polished), can be more than the stone, and polishing the front edge is not inexpensive, either.
    A prefabbed stone counter with the sink hole already there can be cut down to fit, often for only slightly more than one made from other solid surface or Formica(TM) surfaces, and are much more durable.
Similar Threads: Bathroom vanity
Remodel Forum & Blog I touched up wood vanity & want to seal/clear coat. What's the best for a bathroom? Jan 8, 2014
Remodel Forum & Blog Remodeling bathroom with custom vanity question. Jul 19, 2011
Remodel Forum & Blog How to remove cultured marble bathroom vanity countertop? Mar 4, 2011
Remodel Forum & Blog Bathroom- Converting single vanity to double Sep 2, 2008
Remodel Forum & Blog Bathroom vanity replacement issues.. Oct 3, 2005
