Bathroom upgrade - shower mixing valve question -
Discussion in 'Shower & Bathtub Forum & Blog' started by BlueBrummie, Jan 14, 2012.
  1. BlueBrummie
    BlueBrummie New Member
    Jan 14, 2012
    Methuen, MA
    Hi folks,
    New to the forum and am looking for some advice/guidance about an upcoming bathroom renovation. I found a Moen shower faucet that I like but also found that the mixing valve has 3/4" inputs. I believe that this bath is serviced with 1/2" lines only (all dimensions ID). Current shower pressure is more than sufficient. Also, the new shower hardware is a shower head and handle combo, with each having a 2.5 GPM rating. So, my question is, will I be causing myself grief by putting a 1/2 to 3/4" adapter to interface to the new mixing valve? Also, I should say that I'm not likely to use both the shower head and separate handle at the same time, but I may.
    For completeness sake, let me add my home pressure is near 60 PSI at the main. and the distance from the main to the 2nd floor bath is approximately 25 ft of 1/2" feeding off a 30 ft of 3/4", slightly longer for the hot water line. The new shower hardware is the Moen TS270.
    If there's any other pertinent info you'd need to help, just let me know.
    Many thanks for your help,
    Erick
  2. jadnashua
    The company often makes identical valve trim sets in both 1/2" and 3/4" rough-in versions; a 1/2" version will save you some money if it is available. No, it won't hurt performance using a reducer, and might even improve things a little as all valves have some internal flow resistance...a 3/4" one will usually have less than a 1/2" one.
  4. BlueBrummie
    Jan 14, 2012
    Methuen, MA
    Hi Jim,
    Thanks for the reply. After a bit of searching, I haven't been able to find a 1/2" version of the valve set (which is comprised of 1 temp valve and 2 volume valves for the main/handheld units). My inclination is to go ahead with my idea of adding the 1/2 to 3/4 transitions. If anyone else has thoughts/advice, I'd appreciate your input before I take the plunge and order the shower set.
    Thanks again,
    Erick
  5. hj
    Unless something has changed, all Moen valves use the same internal pieces so whether you use 1/2" or 3/4" would be immaterial.
Similar Threads: Bathroom upgrade
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog Installing a Panasonic bathroom exhaust fan in a condo Feb 9, 2017
Shower & Bathtub Forum & Blog Bathroom Remodel Help Jan 29, 2017
Shower & Bathtub Forum & Blog Bathroom Backdraft Jan 28, 2017
Shower & Bathtub Forum & Blog New bathroom renovation pipe gripe Jan 15, 2017
