Bathroom Supply Lines Entry Point
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nelsongg, Jan 1, 2013.
  1. nelsongg
    nelsongg New Member
    Mar 10, 2008
    VA
    I am remodeling an upstairs jack 'n' jill bathroom. I am custom building a 36" floating vanity. The new vanity will be placed in the same place as the old one. The back of the vanity will mount against an outside wall and the left side of it will mount against an inside wall. The problem is currently the supply lines come up through the floor (I'm assuming to prevent freezing) and that will kind of ruin the look of the floating vanity.
    What I would like to do is reroute these lines to enter the new vanity through the inside wall that the vanity will be attached to on the left. This would actually work well for positioning since I plan to mount an undermount round sink 3" off the left wall and 3" from the front edge to maximize limited counter space to right side. I plan to mount the faucet at the 10:30 position to the sink which would be right above where the supply lines would come into the vanity from the side wall.
    Basically, is it OK to have the supply lines come into the side of the vanity?
    If there are any other problems with this, please criticise (I'm married, I'm used to it).
    Thanks,
    Greg
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    There is nothing to say that you cannot run the supply lines any which-way, as long as they are properly supported and protected from freezing.
  4. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    Just curious. I've not heard of the 10:30 position before?
  5. hj
    quote; I've not heard of the 10:30 position before?
    Halfway between the 10:00 and 11:00 positions, which make make it a very precise location.
  6. Terry
    Aug 17, 2004
    Supplying waste and water lines from the side are just fine.
Similar Threads: Bathroom Supply
Plumbing Forum, Professional & DIY Advice Moving bathroom sink water supply lines Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Off center water supply line for bathroom faucet Feb 15, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Faucet Supply Line and Valve Size? Jan 16, 2016
Plumbing Forum, Professional & DIY Advice Bends in Bathroom Faucet Supply Line Jul 8, 2015
Plumbing Forum, Professional & DIY Advice Bathroom drain and supply Lines Jun 22, 2014
