Bathroom skylight dilemma
Discussion in 'HVAC Heating & Cooling' started by Daler, Nov 23, 2012.
  1. Daler
    Daler New Member
    Aug 31, 2010
    Retired commtech
    Cowichan, BC
    Need some feedback about installing an exhaust fan in a skylight.
    The large skylight is shared directly above two shower stalls and so I need something that will rapidly take the moisture away from the light well. Our HRV vent that's mounted in the skylight now is not sufficient to rapidly take away the moisture. I can buy a Nutone/Broan humidity sensing fan (QTREN100H) and mount it on the skylight wall but the manufacturer specifically says it's for flat ceiling mounting only.
    As a potential workaround, my questions are:
    a) has anyone here successfully mounted one of those Nutone's in a skylight wall?
    b) would damage occur to the bearings if mounted on vertical axis?
  2. Terry
    Aug 17, 2004
    Most fans can be mounted either horizontally or vertically. I've done both.
    And I've seen plenty in the skylight well. I installed one in my parents home in 1974 and it worked out just fine.
  4. jimbo
    jimbo Plumber
    While small motors like this with bushings for bearings are optimally operated vertical, that is not the reason for the wall prohibition. Hot humid air goes straight up to the ceiling. The install instructions call for mounting on a flat ceiling up to 12 feet high, for proper operation of the humidity sensor. If you need to mount it on the wall, you could install it for timer operation, rather than sensor operation.
Similar Threads: Bathroom skylight
HVAC Heating & Cooling Radiant Floor Heat in Bathroom and other ramblings... Jan 7, 2017
HVAC Heating & Cooling AC vent and exhaust fan in same bathroom? Aug 12, 2016
HVAC Heating & Cooling Basement Bathroom HVAC Question Apr 17, 2016
HVAC Heating & Cooling Cast Iron Baseboard location in bathroom remodel? Mar 23, 2016
HVAC Heating & Cooling Best place for bathroom fan in slopped ceiling without compromising insulation Jan 20, 2016
