Bathroom sink trap: PVC or Polypropylene
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by adrianmariano, Jan 28, 2014.
  1. adrianmariano
    adrianmariano New Member
    Jan 5, 2007
    Massachusetts
    I'm removing some badly constricted steel pipes that drain my bathroom sink and tub and replacing with PVC. The existing trap under the bathroom sink is a heavy weight 1.5" sched 40 PVC and screws together with metal nuts. I can't reuse all of it because the end piece is glued to some ABS, though perhaps I can just replace that one part.
    Now it seems there is another option for traps: a lighter weight "slip" joint trap made of polypropylene instead of PVC. This might be easier to install because the slip joint provides more flexibility when making the final connections. I think this is 1.25" pipe, so it's a bit smaller.
    My question is, does it matter which type of trap I use? Is one of the two types superior? Or should I just pick my trap based on what turns out to be the easiest to install?
  2. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    No it doesn't matter. The only thing that matters is "no leaks".
  4. Terry
    Aug 17, 2004
    I prefer tubular traps over the solvent weld traps. It's also easier to remove them when needed, in case you need to run a hand snake through the drain.
  5. adrianmariano
    Jan 5, 2007
    Massachusetts
    Thanks for the advice.
    I would say there's a second thing that matters beyond "no leaks", which is that water actually drains. Or to be more succinct: no clogs. And of course I'd like it to work properly for a long time, so no leaks or clogs in 20 years. My existing piping doesn't leak...but it also doesn't drain very well. There's a temptation to think that the heavier built product is better, that it will last longer, and so on. But it doesn't have to be true.
Similar Threads: Bathroom sink
Plumbing Forum, Professional & DIY Advice Bathroom sink faucets: ceramic cartridge vs. washerless cartridge;PVD nickel vs regular Today at 5:58 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Yesterday at 1:36 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Sunday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Bathroom Sink - Popup - No Through Pivot Rod Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Bathroom Sink Stub Out Too Close. Jan 24, 2017
