Bathroom sink plumbing question (very basic)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by eoren1, Mar 6, 2013.
  1. eoren1
    eoren1 New Member
    Aug 20, 2005
    Massachusetts
    So our bathroom sink has been very slow to drain and I finally decided to do something about it. Figured one of the kids dropped a lego piece and it was wedged in the trap. Looked under, undid the trap and found nothing. I did note the perplexing design of the piping though. Wondering if there is any reason why I can't/shouldn't disassemble this thing and do a simple drop/trap/elbow/out setup. I have the clearance to lower the trap so it can then be at the height of the exit pipe (sorry, I know that's not the right term).
    Thanks in advance,
    E
  2. hj
    Someone went to a lot of trouble to make a very complex, and completely illegal, drain connection. It is the old story of someone thinking "anyone can do plumbing" if he has enough pipe and fittings.
  4. eoren1
    eoren1 New Member
    Aug 20, 2005
    Massachusetts
    Thanks HJ.
    So can this 'anyone' undo the above and just get a longer straight PVC hooked to the trap and then elbow out?
    By the way, why is this 'illegal'?
    Appreciate the help for this newbie.
    E
  5. eoren1
    eoren1 New Member
    Aug 20, 2005
    Massachusetts
    Reading a bit more, I guess this is a convoluted 'S' trap. Just ordered a new faucet/drain assembly as the one up top needed to be updated and will take out all of this piping and replace with a proper P trap.
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    A very good ideal !
    that look likes something the wizard of OZ would think of
  7. jimbo
    jimbo Plumber
    yes it is an S. Just use a longer tailpiece down from the sink so that the trap arm outlet goes straight to the wall.
  8. Cameron Fields
    Cameron Fields Implementer/Inventor
    Mar 5, 2013
    2 year lawn , Theorist, Designer/inventor,Animator
    Florida
    Wow, I would replace it. I think that it might flow a tad bit faster but you never know.
  9. eoren1
    eoren1 New Member
    Aug 20, 2005
    Massachusetts
    Well...in for a penny, in for a pound...right?
    Just ordered a new Moen Eva 6410 faucet and drain to replace the vintage 60's model attached up top. Just got back from HD with all the stuff I need to put in a nice clean P drain below. Nice Sunday project coming up.
    Thanks everyone!
  10. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    And why the need for the PVC? why not tubular?
  11. eoren1
    eoren1 New Member
    Aug 20, 2005
    Massachusetts
    So the project is done...sort of - need some help/advice
    I removed the old faucet and all PVC from below (man that was a PITA). Then installed the new faucet and piping. All seemed fine. Of note the PVC threaded into the discharge pipe with a 1 1/2" male threaded piece. I primed/glued at two spots and thought I was good to go. Turned on the water...okay.
    Then, at the point where the old setup would start backfilling the sink, I was now getting water out of the attachment to the sink drain. I disconnected everything and shined a light into the discharge pipe - clean to the turn. Reassembled and tightened as far as I could and ran water at a slow level...fine. Bit faster and the same thing happened.
    So I'm guessing the old S piping was to make up for something else happening 'down the pipe'. Think I'm stuck now and need to call my plumber but was hoping someone could chime in with their thoughts on what might be wrong.
    Thanks
    E
    Old faucet
    New faucet
    New piping
  12. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Waste line needs to be rodded out.
  13. MASTERPLUMB777
    Aug 6, 2007
    Texas
  14. eoren1
    eoren1 New Member
    Aug 20, 2005
    Massachusetts
    Hmmm....guessing that I've moved beyond the realm of DIY if I need to buy something more than a handheld version.
  15. hj
    Lavatory drains SELDOM drain fully when the faucet is flowing aerated water directly on to them. You can only tell if it needs snaking when the faucet is turned off with water in the sink. I would NOT have used sch.40 drain fittings, but that is just a personal preference.
  16. Gordan
    Gordan New Member
    Feb 2, 2013
    SE PA
    Not sure what you mean by "getting water out of the attachment to the sink drain." Do you mean where the sink tailpiece goes into the trap? If so, there should be a little plastic compression ring under that compression nut. If there isn't, it will leak. Your drain should be water tight no matter what happens in the sink. The tailpiece also does not appear to be going straight into the trap - looks like it's at an angle. Enough of an angle will definitely create issues with sealing.
  17. eoren1
    eoren1 New Member
    Aug 20, 2005
    Massachusetts
    So the plumber came and fixed it all...
    Not sure how far he had to go or what tool he ended up using (I was at work at time) but he texted me back the root of the problem.... "dental floss" - we don't even use the stringy stuff (prefer the single use ones) which means that stuff predates our move to the house 3 years ago
    Also tightened up my piping underneath and got that damn plunger part of the faucet to stay up when trying to depress the part that seals the sink to fill with water. I hadn't been able to figure that one out and was too tired/sore at that point to try.
    He was due to come in at some point to remove our old whole house trap so able to kill two birds with one stone.
    Thanks for all the help guys.
Similar Threads: Bathroom sink
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Yesterday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Bathroom Sink - Popup - No Through Pivot Rod Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Bathroom Sink Stub Out Too Close. Jan 24, 2017
Plumbing Forum, Professional & DIY Advice rust particles in bathroom sink drain Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Advice on bathroom sink drain Jan 22, 2017
