Bathroom Sink "Gurgling"
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nin28, Sep 17, 2008.
  1. nin28
    nin28 Member
    Apr 15, 2007
    New York
    I have a bathroom sink that after running the water for a minute or two will gurgle after the faucet is turned off. The sink drains perfectly fine. Is this an indication of something in the future that could go bad? Thank you.
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    Gurgling generally (not always) indicates a venting problem.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Yes a venting problem...a clogged vent or no vent.
  5. nin28
    nin28 Member
    Apr 15, 2007
    New York
    Thanks for the replies. The sink is on the 2nd floor and about 3'-4' from the main waste pipe, which is vented on the roof. I don't get any gurgling from any other sinks in the house. Is it possible that this 4' run to the waste pipe needs its own vent? If that is the case I might just live with the gurgling because I would have to cut into a cast iron pipe and that really doesn't interest me. Thanks for any additional help!
  6. Cass
    Cass Plumber
    Nov 12, 2005
    How old is the house?
  7. nin28
    nin28 Member
    Apr 15, 2007
    New York
    The house was built in 1959, I believe.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It is either a poorly vented p-trap or, an s-trap.
    A partial clog may be involved.
  9. nin28
    nin28 Member
    Apr 15, 2007
    New York
    I will check the P-Trap and see if there is any clog there. Do you think I may have to run an auger through the waste pipe to clean it out? Thanks.
  10. bombjay
    bombjay New Member
    Mar 11, 2008
    A proper drain cleaning is in order.A drain cleaner can yank the trap and run up a little and make sure the vent is open and down to give the line a good cleaning.
    Good luck.
  11. nin28
    nin28 Member
    Apr 15, 2007
    New York
    OK. I took everyone's advice and popped open the p-trap and guess what, not clogged at all. That was surprising. So then I detached the pipe running from the sink to the p-trap and found that that was where the clog was. The pipe had about 1 centimeter hole where the water could go through. So took apart all the piping and gave it a good cleaning. I just installed the sink last year and I can't believe how dirty it got so quickly. I've used drain cleaner and that did nothing. Maybe I just used the wrong type of drain cleaner. Oh well. Cleaned it the good old fashioned way. Thanks for everyone's help.
  12. jadnashua
    As you found out, drain cleaners often don't do much...they are best avoided - save your money.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    OMG who would have thought....:eek:
Similar Threads: Bathroom Sink
Plumbing Forum, Professional & DIY Advice Bathroom sink faucets: ceramic cartridge vs. washerless cartridge;PVD nickel vs regular Saturday at 5:58 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Friday at 1:36 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Bathroom Sink - Popup - No Through Pivot Rod Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Bathroom Sink Stub Out Too Close. Jan 24, 2017
